Stan, since you're on 9.05 and new to BPMs: This could have been
accomplished without knowing (or cutting & pasting) any ABL code. For
action, choose "set the specified field of the changed row to the
specific expression", then click on the 3 blue items to fill in the
details. Does the same stuff as Jose's ABL code below, but easier to
get started with.
Brian.
Of Jose Gomez
Sent: Monday, February 27, 2012 2:58 PM
Subject: Re: [Vantage] Check box defaults
YEs that is the correct area,
There you need to add what is called a new Post Processing directive,
then
under the Actions you will select Run ABL Code and you type that code in
there.
Hope that helps.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Mon, Feb 27, 2012 at 1:45 PM, Stan Chmura <schmura@...>
wrote:
get started with.
Brian.
Of Jose Gomez
then
there.
Hope that helps.
*Jose C Gomez*
*Software Engineer*
E: jose@...
wrote:
> **familiar
> Jose, perhaps you can provide me a little more info. I am not yet
> with BPM, I am I a longtime user of Vantage 6.1 and only now in theprocess
> of loading master files in Epicor 9.05. I am working only on a test9.05 db
> at this point. I've looked around a bit on the BPM set up but need alittle
> more to get started. I was in the area called Method Directives whereI
> found the GetNewCustomer you mention. But from there I lost it. Am Iin
> the right place to create a BPM like you suggest and if so where doesthe
> syntax you provided go?In
> Thanks in advance for your interest and assistance!
> Stan
> This communication is intended only for use by the addressee(s) named
> herein
> and may contain technical data as defined in the International Traffic
> Arms Regulations (ITAR) 22 CFR 120.10. or the Export Administrationto
> Regulations. Export of this material is restricted cannot be exported
> foreign persons or foreign destination without prior written approvalfrom
> the U. S. Department of State or the US Department of Commerce.Behalf
> OfttCustomer.RowMOd='A':
> Jose Gomez
> Sent: Monday, February 27, 2012 10:46 AM
> BPM my friend, post processing on GetNewCustOmer.
> FOR EACH ttCustomer WHERE ttCustomer.RowMod='U' OR
> Assign ttCustomer.yourCheckBox=true<http://www.facebook.com/josegomez
> ttCustomer.otherChekBox=false.
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/>"Acknowledgements"
> On Mon, Feb 27, 2012 at 10:34 AM, stanchmura <schmura@...>
> wrote:
> > Is there a way in epicor 9.05 to change check box defaults? e.g. Two
> > defaults in the customer master file are "True or checked" for
> > "Labels" and "Acknowledgements". Next to those is "Statements". It's
> > default is "false or unchecked".
> > Not all my customers require labels, but all require
> > and Statements". So I would like to change the defaults forStatements
> > from False to True; and for labels from True to False. (I don't seehave
> > these options anywhere in the company Sales module config.) Any one
> > know if or how that can be done?
> already linked your email address to a yahoo id to enable access. )and
> Crystal Reports and other 'goodies', please goto:[Non-text portions of this message have been removed]
