As far as I know no you cant. You have to do it this way. At least
that is what epicor told me.
--- In vantage@y..., "Mike Lowe"<MLowe@c...> wrote:
> Rather than modifying the ini and vtg files can't you just create
a Vantage icon
> with the 'old style-like in the Novell days' long Vantage command
path?
> Mike
> ____________________Reply Separator____________________
> Subject: [Vantage] Citrix and Vantage 5.1
> Author: <vantage@y...>
> Date: 4/25/02 4:28 PM
> To all Citrix Guru's and/or Gods I ask a humble Question.
> We are running vantage on a typical LAN. We have a citrix server
> that is used to access company programs from the internet only. We
> are not using citrix locally with thin clients. Anyway, when we
were
> on version 4.0 applying vantage to citrix then creating an ica
file
> was a breeze.
> However, as some may know. Installing 5.1 a little more
cumbersome.
> I have corrected citrixvantage.ini and citrixvantage.vtg file have
> done the local install of progress on the citrix server. Believe i
> have done everything else. Creating Vantage as a published app.
> created ica file and vola when i click in it it logs me into the
> citrix server but when it tries to load vantage it says the
> application could not be started.
> the working directory is pointing to the main database. I have
> followed all instructions supplied by epicor.
> If anyone has the slighest tip i would be more then happy to hear
it
> Thanx
> mtrzaska@s...
must have
Builder and
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
