Citrix and Vantage
It looks like your client and db are not the same version. Check to see
if the upgrade of the client flowed to the citrix server.
Of llhellings
Sent: Thursday, June 14, 2007 4:08 PM
Subject: [Vantage] Citrix and Vantage
We are running Vantage 8.03 305F on a Citrix Metaframe Presentation
Server 4.0. We am getting the following error when we right-click in
the Part Field in Part Maintenance and select Job Manager. Has anyone
seen this type of message before when using Citrix and Vantage?? We
do not get this error when connecting to Vantage directly on a
desktop, only through Citrix.
Exception caught in: Epicor.Mfg.BO.JobManager
Error Detail
Message: ERROR condition: Parameter number 8 (table ttJMSupply)
mismatch. Has 23 fields - client schema has 22 fields. (8030) (7211)
Type: Error
Program:
Method:
Table:
Row:
Field:
Stack Trace
at Epicor.Mfg.Proxy.JobManagerImpl.GetMatrix(String ipPartNum,
String ipPartDescription)
at Epicor.Mfg.BO.JobManager.Epicor.Mfg.IF.IJobManager.GetMatrix
(String , String )
at Epicor.Mfg.UI.Adapters.JobManagerAdapter.GetMatrix(String
ipPartNum, String ipPartDescription)
at Epicor.Mfg.UI.App.JobManagerEntry.Transaction.GetMatrix(String
I am having problems with my users getting into Vantage through Citrix.
One user can get in. Then usually anyone else gets the messages below.
The funny thing is this morning. I had 3 people in Vantage with no problems,
now I can only get 1 person in.
Everyone else gets:
errno=22 reading promsgs file. It may have been deleted
Unable to format message number 290
Unable to format message number 96
Unable to format message number 6061
Then the splash screen disappears
I have seperate Vantage.vtg and .INI files set up. Each user has their own
Vntgwork folder.
I'm using Vantage 4 and Win2K for the server.
I tried support and was emailed instructions to reinstall my Terminal
Services. After looking they are installed like the instructions say.
Any ideas would be helpful.
Nancy Dunn
Winco Industries
ndunn@...
We had the same problem on Vantage 5.0. I assume the same philosophy
below applies to Vantage 4.0 but you might want to check with support:
Page: 1236MPS
Summary: PG, Terminal server cannot find promsgs.dll
AnswerBook: Vantage ChangeRequests
Problem:
Citrix meta frame & Terminal server give error message "cannot find
promsgs.dll" this message may display on the screen or may only be
showing on the .lg file.
Resolution:
For Terminal Server / Citrix clients, install all of the Progress Client
Products (ClientNetworking, Query/Results, Report Builder) to the
Terminal Server.
After installing Progress to the Terminal Server, you will need to
create a unique .Vtg and a unique Vantage.ini for the clients to use.
Take a copy of the Vantage.Vtg and give it a new name (i.e. TSVntg.VTG)
Edit this new VTG and change the Executable= to point to the local
install of Progress and change the IniFile= to point to a new TSVntg.INI
file. Sample below.
[Vantage Startup]
Executable=C:\Epic50\Progress\bin\prowin32.exe <-----
Database=V:\Vantage\db\vantage
IniFile=V:\Vantage\TSVntg.ini <-----
ParameterFile=V:Vantage\db\Vantage.pf
ConnectOptions=-N TCP -H jay2000 -S vntgdump -ld vantage
TempDirectory=C:\Vntgwork
StartupProcedure=mainmenu.w
OtherParameters=-rand 2 -q -basekey ini
After the new TSVntg.VTG is complete, make a copy of the Vantage.ini
file and give it the same name we used in the TSVntg.vtg which is
TSVntg.INI.
Edit the new TSVntg.INI file and change the DLC= and the PROBUILD= in
the [Startup] section to reflect the local Terminal Server installation
path, indicated by the arrows below.
Example:
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
DLC=C:\Epic50\Progress <------
Use-3D-Size=No
PROBUILD=C:\Epic50\Progress\Probuild <------
PROPATH=.,V:\Vantage
UseSourceEditor=yes
;EditorConfigPath=d:\Prowork\proedit
PrinterFont=Courier New,Size=12
AllowDesignMode=no
Finally, on the Terminal Server change the eMfg icon properties -->
ShortCut so the icon points to the new TSVntg.vtg just created.
Sent: Wednesday, May 16, 2001 12:08 PM
To: Vantage Onelist (E-mail)
problems,
Everyone else gets:
own
Vntgwork folder.
Nancy Dunn
Winco Industries
ndunn@...
------------------------ Yahoo! Groups Sponsor ---------------------~-~>
Become a member FREE at http://www.searchdatabase.com?Offer=yahoo5
today.
Save time finding the best Database Development and
Management information available on the Internet.
Our targeted search engine and dedicated editorial staff "cut out the
clutter" by aggregating the best links and the most relevant database
news for you
every day.
http://us.click.yahoo.com/_w3RtC/rGiCAA/bT0EAA/P0AVlB/TM
---------------------------------------------------------------------_->
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
http://groups.yahoo.com/group/vantage/files/. Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Error Detail
Type: Error
Program:
Method:
Table:
Row:
Field:
Stack Trace
(String , String )
