This is a Classic customization in Purchase Advisor that pulls in a UD field from PO Line. I suffered many headaches getting it working, but then I installed it in Prod (both have the same UD fields) and it threw this error during runtime.
Then I went back to Test and did another test and I got the same error.
I don’t understand what changed or why I wasn’t getting this error before, nor how to fix it. I Test the Code and it compiles fine.
I thought it may have been client cache so I cleared that and logged back in… same error.
I did something similar in PO Suggestions to pull in a UD field from Requisition Lines.. and that works fine.. still.
I checked that my Referenced Assemblies are still there:
- Erp.Adapters.PO
- Erp.Contracts.BO.PO
Here is my code:
Code
// Custom code for PurchaseAdvisorEntryForm
// Pull UD field Character02 from PO lines
using System;
using System.ComponentModel;
using System.Data;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
// Module Level Variables
private EpiDataView edvPurchased;
private POAdapter poAdapter;
// Get the PurchasedBefore EpiDataView
this.edvPurchased = (EpiDataView)oTrans.EpiDataViews["PurchasedBefore"];
this.edvPurchased.EpiViewNotification += new EpiViewNotification(this.edvPurchased_EpiViewNotification);
// Add column for the UD field
DataColumn dc = new DataColumn();
dc.ColumnName = "PO_Character02";
dc.Caption = "Deliver To";
edvPurchased.dataView.Table.Columns.Add(dc);
edvPurchased.dataView.Table.Columns["PO_Character02"].ExtendedProperties["ReadOnly"] = true;
// Initialize POAdapter
poAdapter = new POAdapter(oTrans);
poAdapter.BOConnect();
edvPurchased.EpiViewNotification -= new EpiViewNotification(this.edvPurchased_EpiViewNotification);
edvPurchased = null;
if (poAdapter != null)
poAdapter.Dispose();
poAdapter = null;
private void edvPurchased_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
if (args.Row < 0) return;
for (int i = 0; i < edvPurchased.dataView.Table.Rows.Count; i++)
DataRow row = edvPurchased.dataView.Table.Rows[i];
// Only process rows with a PO number and line, and where our column is empty
if (!string.IsNullOrEmpty(row["PONum"].ToString()) &&
!string.IsNullOrEmpty(row["POLine"].ToString()) &&
string.IsNullOrEmpty(row["PO_Character02"].ToString()))
string poNum = row["PONum"].ToString();
int poLine = Convert.ToInt32(row["POLine"]);
try
// Clear previous PO data
poAdapter.ClearData();
// Load the PO
poAdapter.GetByID(poNum);
// Find the matching PO detail line directly (UD fields are already here)
DataRow poDetailRow = null;
foreach (DataRow detailRow in poAdapter.POData.PODetail.Rows)
if (Convert.ToInt32(detailRow["POLine"]) == poLine)
poDetailRow = detailRow;
break;
// Populate grid column
row.BeginEdit();
if (poDetailRow != null && poDetailRow.Table.Columns.Contains("Character02"))
row["PO_Character02"] = poDetailRow["Character02"].ToString();
else
row["PO_Character02"] = "No DeliverTo";
row.EndEdit();
catch (Exception ex)
// In case of error, fill with message
row.BeginEdit();
row["PO_Character02"] = "Error: " + ex.Message;
row.EndEdit();
