I need to get the OrderDtl NeedBy and ShipBy dates, not a hard thing and I’ve done it plenty of times but in this case I need both and wondering which is more efficient code; two DB calls direct to the field or one DB call to pull both and then convert to string or is my two examples total trash and there is a better way?
Option 1:
lineSBD = Convert.ToDateTime( Db.OrderDtl.Where( r => r.Company == Session.CompanyID && r.OrderNum == OrderNum && r.OrderLine == oLine).Select( r => r.RequestDate ).Min() ).ToString("MM/dd/yyyy");
lineNBD = Convert.ToDateTime( Db.OrderDtl.Where( r => r.Company == Session.CompanyID && r.OrderNum == OrderNum && r.OrderLine == oLine).Select( r => r.NeedByDate ).Min() ).ToString("MM/dd/yyyy");
Option 2:
var lineDates = (from r in Db.OrderDtl where r.Company == Session.CompanyID && r.OrderNum == OrderNum && r.OrderLine == oLine select new {oRow.NeedByDate, oRow.RequestDate}).FirstOrDefault();
lineNBD = string.Format("{0:MM/dd/yyyy}", lineDates.NeedByDate);
lineSBD = string.Format("{0:MM/dd/yyyy}", lineDates.RequestDate);
