Hi Dustin,
Try...
edv.dataView(edv.Row)("Date01") = DateAdd(DateInterval.Year, 1, DateValue(edv.dataView(edv.Row)("Date03"))
HTH,
Ross
Try...
HTH,
Ross
--- In vantage@yahoogroups.com, melissa hietala <kevmel822@...> wrote:
> IÂ am creating a customization and what I need to happen is that when the user
> changes the value of the "PREmployee.Date03" field, I need the
> "PREmployee.Date01" field to be automatically set to 1 year ahead of the
> "Date03" value. Im struggling to find a way to make this work. Below is what I
> have so far. Any thoughts on the syntax to perform this?
> Thank you
> Dustin Biniek
> Â
> Private Sub PREmpMas_AfterFieldChange(ByVal sender As object, ByVal args As
> DataColumnChangeEventArgs) Handles PREmpMas_Column.ColumnChanged
> Â Â '// ** Argument Properties and Uses **
> Â Â '// args.Row("[FieldName]")
> Â Â '// args.Column, args.ProposedValue, args.Row
> Â Â '
> Â Â 'Add Event Handler Code
> Â Â '
> Â Â Â Â Â Â Â Dim edv As EpiDataView = CType(oTrans.EpiDataViews("PREmployee"),
> EpiDataView)
> Â Â Select Case args.Column.ColumnName
> Â
> Â Â Â Case "Date03"
> Â Â Â Â Â Â Â Â edv.dataView(edv.Row)("Date01") = edv.dataView(edv.Row)("Date03")Â +
> 365?????
> Â Â Â Case Else
> Â
> Â Â End Select
> Â
> Â End Sub
