Combo-box from DataView
Hi All, I’m building a proof of concept Dashboard application in App Studio. I have a simple combo-box with the datasource being a Dataview. The combo-box will only show the first (or what is understood to be the “current”) row of the dataview as a choice. Kinetic 2024.2.12. Here is how it is set up:
Data - EpiBinding: Transview.Combo02 (yes this is intialized - I can see it in the debugger)
Reusable Combo - View Name: DataD (yes it has 4 rows of data in it derived from a BAQ. I can see it in the debugger)
Reusable Combo - View Column Name: UD29_ShortChar04
Advanced - Drop Down Style: DropDownList
Advanced - TextField: UD29_ShortChar04
Advanced - ValueField: UD29_ShortChar04
I’ve tried multiple variations of this, populating my Dataview in a number of ways - copying a subset of records from another Dataview, using a BAQ with a Static Filter - and the result is always the same. Only the current (first) row shows as an option in the combo box.
I can successfully show options in my combo-box using a service call. UserCodes reusable combo works like a dream (but that’s not where my data is!). Using a GetRows call to UD29Svc works great too (except the where clause won’t populate), but I do get data.
Any insight would be appreciated.
Thanks.
Solved the problem - do not specify a View Column Name in the Reusable Combo section. So the final settings were
I found the answer in this post:
