In Vantage 6.1 and earlier we were able to go in and change the Comment
Text field size from (1000) to say (3000) and then be able to use the
additional characters when needed.
We are now going through loading our data into a 8.03.403b database and
those fields that were over (1000) in size are now being truncated as
the data is moved in.
Has anyone been able to increase the field size of a particular field in
8.03.403? If so, are there instructions as to how to accomplish this
printed somewhere? Any assistance would be appreciated.
Thanks!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
WWW: http://www.aceprecision.com
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
Thanks!
Paul E. Pachniak
Accounting Manager
Fax: 262-252-4974
