On Fri, Mar 6, 2015 at 8:08 AM, erp07052@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p>OK - this should be simple and straightforward...but not so lucky<br></p><p>
Â
using a PCLOOKUP.DataLookUp to lookup data from a configuration LOOKUP table
which is almost exactly the same as the OUT OF THE BOOKÂ sample
but It doesn’t work … it always returns a null value.. There are NO error messages
Â
Here is the lengthy documentation on this command
- DataLookup(<lookuptable>,<columnname>,<rowname>) returns single value
Â
Code used to call from a On Change field - is
Â
Inputs.Comments.Value = PCLookUp.DataLookup("TYPETABLE","PARTNUM","8");
Â
I’ve hard coded an “8†as the row value .. but i've also used values from other inputs
 it doesn’t make a difference. The system  never returns a value from the table.
The lookup table is populated
the columns are
seq1 - TYPE - string 1
seq2 - DESC - srting 50
seq3 - PARTNUM - string 20
table is TEMPLATE
column set is TYPES
lookup table is TYPETABLE
any ideas?
regards
<p></p></div> <div style="color:#fff;min-height:0;"></div>
I have only played with this a bit, but here's my experience.
I had issues importing my spreadsheet with the table setup I best-guessed from the documentation. Someone recommended entering a new table in Configuration Lookup Table entry, then exporting that and examining it to get a good format.
If this is your issue maybe this will help.
Joe Trent
Bigham Ag
