Configurator Blank Title 69769
Every time you make a change to the configurator, you would also have to make those same changes to any affected parts you've saved to the part master. Whether you decide to save each configuration as a part or not will very much depend on your environment.
We have about a dozen configurations that we've decided to make into part numbers for forecasting and stockability reasons. Everything else goes through as MTO or we'd have, potentially, thousands of part numbers to maintain. Challenges here are that those units "hide" in WIP until the sales order ships so no easy way to stock. Also decisions have to be made on how to handle RMAs. (If they can be salvaged, we usually disposition to a job and "remake" into a stocked refurb item.)
Good luck.
--- In vantage@yahoogroups.com, "c.krusen1" <ckrusen1@...> wrote:
> Tim -
> Do you even need to push the configured part to the Part Master?
> If you want to ensure the most recent configuration definition is used, don't save it to the Part Master, but instead have it configured on each use. A part configured in a quote, can be pushed to an Order. Then during Job creation, the demand for the mfg'd part on the order will pull the details from the quote.
> If you're concerned that a definition might change between the time a part is quoted and the job is created, then you'll have to manage that outside of the configurator. I think you can re-run the configurator on a part from within Job management, and could "re-process the cfg using the new definition.
> Calvin
> --- In vantage@yahoogroups.com, "Tim Vonderhaar" <tvonderhaar@> wrote:
> > Thanks again Calvin for continuing to help with this issue.
> > 1) Given there doesn't appear to be a clean way to implement our first request, we will defer that for now and will just use separate configurators by themselves.
> > 2) You are correct. I am concerned that there could be a disparity between the configurator definition and the results stored with a P/N. If the connection between the stored P/N and the configuator definition does not have any built in "sync" capability, any updates to the configuator definition will render the stored P/N out of date. We need to guarantee that this won't happen, nor do we want a user to have to remember to use the Engineering Workbench or some other manual method. Is it possible to not push a configured part into the part master any only keep the instance of the part local to the line item of the sales order? Is there any other option to address this?
> > Tim
> > --- In vantage@yahoogroups.com, "c.krusen1" <ckrusen1@> wrote:
> > > Correction to my previos post.
> > > You can edit the MoM of a configurator generated part. Eng Workbench was only disabled because I hadn't checked out the revision.
> > > So it looks like you could re-configure the part (using the configurator), or use Eng Wrkbnch.
> > > Calvin
> > > > 1. I am pretty sure you can nest configurations. I've heard (but never experienced) that there are no safeguards from making a circular-reference (cfg#1 --> cfg#2 --> cfg#3 --> cfg#1). I've seen a topic in the documentation called "Inputless Configurator". Maybe that's what your lower level configurations need to be.
> > > > Ok, I had a rather long explanation for your second question, but then started doubting myself. So instead of telling you something that might be incorrect, I'll just talk outloud.
> > > > I'm assuming what your real concern is that a part created by the configurator - that ends up being saved to the Part file - will be redefined if at a later date a changed configurator definition, that results with the same P/N, but a different MoM. Is this your concern?
> > > > A Part created with a configurator, doesn't have MoM, but has remembered all the configurator choices when it was created. If you Look at the part in the Part file, you'll see that the Engineering Workbench is disabled, while the Configurator is enabled.
> > > > I'm guessing a lot of testing will be the only thing to answer your questions.
> > > > Calvin
> > > > > Thanks for the reply Calvin.
> > > > > 1. I agree that we should keep things simple, but the question still remains, is it possible to launch a configured part from a configured part selection?
> > > > > 2. Thanks for the clarification on revisions of a configurated part. However, I am still unclear as to how config changes may effect a part already in the product master that had been previously created from the configurator. Do we have to rerun the configurator to insure that a part already in the part master gets the updated items from the config or is there some magic that will run the configurator behind the scenes if a part previously created from the configuator is selected on a sales order line? I would never do this, but if the config rev is 'A' and the part master has a rev 'A' that was created from the configurator, then we update the configurator, keep the revision a 'A', now what the configurator will generate is different than what the part master has. How do I insure they stay the same? Should we not push a configured part to the part master? Is there some function we have to run on the line order (i.e. get details) that will get the update from the config?
> > > > > > 1. If it's your first configurator, keep it simple. We have 3 similar products (installed in water, earth or concrete) that are built nearly the same, but it was just easier to make a different configurator for each of the famaily members.
> > > > > > 2. Each Version of a part can only have one configurator setup (the pages, rules, etc...) version. Changes to the config setup can be done without changes to the Part rev. It's up to you to determine the level of revision control on the configurator setup.
> > > > > > Calvin
> > > > > > > We are working through setting up our first configurator project and have run into a couple questions.
> > > > > > > 1) Is is possible to call a configured part from a configured part?
> > > > > > > For example, we have a product family that has 10 or so similar products. Creating on giant configuration for the entire family will be a nightmare to maintain. Our thought would be to create a simple starter configured part that allows the user to select the first level (unit size) of the product family which will then call the specific configured part for the detail of that specific size.
> > > > > > > 2) We are confused by how to enforce the latest revision method will get used on a sales line.
> > > > > > > When a part and it's method is generated by the configurator, it gets associated with the line and allows a job to be created via the scheduler. It also appears the part and it's method is also pushed into the part master under the current revision of configuration. For the sake of the example, say the revision is A. Now say time elapses and the configurator gets updated a few times and it's now up to revision C. I understand that if I run the configurator again, it will generate the part along with the revision C method. What I am unclear of is, if a user does not use the configurator decides to use the part from the part master, am I correct is assuming it's revision will only be A? How do we insure we get the current configurator revision?
> > > > > > > Thanks,
> > > > > > > Tim
Does anybody have a sample of the code they ran to pull thru the MOM
with parts in a configurated part setup. I think it has to be set with
a keep when rule, but I don't know for sure.
Gene
All the Keep when rule does is determine if that placeholder will stay
on the configured part or not. If you are doing your configuration in a
Sales Order, there is nothing on the Sales order to give you a list of
the parts that will be returned without some kind of programming. A
quote you can get details and that will bring in the MOM from the parts
being returned. I would do the entire thing in a quote first to see if
you are getting the right responses back after getting Details, then try
it in a sales order pushed to a job. For the Job to work the same as a
Quote though, you will need to be sure to put both the JobAsmbl and
QuoteAsm rules outputting the same data. Which one actually pushes data
out depends on whether you are doing the configuration and detail
getting from the Quote or the Job. The GetPartDefaults() brings in the
Description, and other stuff relating to the Part masterfile record is
all. The operations and MOM are brought in when the GetDetails process
is run, either from manually creating the Job, allowing MRP to create
the Job(be sure the top level part has 'Process MRP' checked on the
Plant tab of the Part Masterfile, or MRP will NOT process it).
* Format for the Standard ASM rules
Keep When Not (P80_P010 Matches "")
Set Field JobAsmbl.PartNum = P80_P010
Set Field QuoteAsm.PartNum = P80_P010
GetPartDefaults()
Set Field QuoteAsm.Number02 = P80_L010
Set Field JobAsmbl.Number02 = P80_L010
Set Field QuoteAsm.QtyPer = P80_Q010
Set Field JobAsmbl.QtyPer = P80_Q010
* Format for the Standard MTL rules
Keep When Not (P85_P010 Matches "")
Set Field JobMtl.PartNum = P85_P010
Set Field QuoteMtl.PartNum = P85_P010
GetPartDefaults()
Set Field QuoteMtl.Number02 = P85_L010
Set Field JobMtl.Number02 = P85_L010
Set Field QuoteMtl.QtyPer = P85_Q010
Set Field JobMtl.QtyPer = P85_Q010
Set Field QuoteMtl.RelatedOperation = Int(P85_R010)
Set Field JobMtl.RelatedOperation = Int(P85_R010)
Paul Millsaps
Time Manufacturing
254.399.2170
paulm@... <mailto:paulm@...>
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mistransmission.
If you receive this message in error, please immediately delete it and
all copies of it from your system, destroy any hard copies of it and
notify the sender. You must not, directly or indirectly, use, disclose,
distribute, print, or copy any part of this message if you are not the
intended recipient.
Of gmack110256
Sent: Wednesday, October 15, 2008 1:56 PM
Subject: [Vantage] Configurator
Gene
First of all apologies if this is covered elsewhere, I have searched
and can't find anything similar so will ask the question...
I have a configurator created which includes a number of fields in an
input page.
What I'd like to know is, is there any way of having the values entered
in that input page be saved back to some user defined fields in the
sales order form, and if so how is it done ?
Ultimately I want the values entered into the input page to be viewable
as job instructions when/if a job is created for that product.
I'm using Vantage 8.03.405A.
Many thanks
WAM
I may not be much help , as we are still on ver 6.10.541.
Â
In our 'old' version you can use 'set field in Rules' only for 4 tables , it's my understanding that ver 8+ allows more tables to have 'fields set' with 'Rules' , which run during the 'get details' phase - if so, that is where I would try to do it. Don't know if the tables you need
would be availabe. Or maybe a custom routine will be needed to save your data, the routine would need to know which Sales Order you are dealing with.
Date: Wednesday, November 5, 2008, 8:51 AM
input page.
Many thanks
WAM
Like Bill said, you can use the SET FIELD directives in the Rules section.
In your case, I would populate the JobComment field with the instructions.
That way, you don't have to store any values for future use.
Mark W.
If you are creating the configured part as a sales order, then the rules
do not run until the actual job is created, so it cannot be done easily
through rules if you want the data to appear on the sales order. If you
just want the data on the Job, then you can do it through a Set Field
on the rules, at the Alt level if the data should appear at the Header
level on the job.
There is a way to push the data on to the sales order, it is what I do
for configured parts, where I push some data on to the PickListComment,
which goes onto the job in the job Comment section. It utilizes a
procedure called UpdateTableBuffer, which should be in your lib folder
on the server. maker sure that procedure file is there, and this should
work.
The code uses a decimal field I store the current quote/order line and
number in from P01.
Here is the code I use:
/* this section posts the data from P80_ED_JOBCOMMENT into the line
detail database */
If P01_QUOTENUM<>0 AND GetContextMode() = "ORDER" Then Do:
Find First OrderDtl Where OrderDtl.Company = P01_COMPANY
and OrderDtl.OrderNum = Int(P01_QUOTENUM)
and OrderDtl.OrderLine = Int(P01_QUOTELINE)
No-Lock No-Error.
IF AVAIL OrderDtl THEN
IF (OrderDtl.PickListComment = "") THEN
RUN
lib\UpdateTableBuffer.p
(input BUFFER OrderDtl:HANDLE,
'PickListComment', P85_ED_JOBCOMMENT).
ELSE
RUN
'PickListComment', "Revised: " + P01_CHR_DATETIME + '~n'+
'~n' + OrderDtl.PickListComment + '~n'+ '~n' + P85_ED_JOBCOMMENT).
End.
Paul Millsaps
Time Manufacturing
254.399.2170
intended recipient.
Of wamitch1012
Sent: Wednesday, November 05, 2008 7:52 AM
input page.
Many thanks
WAM
I use the UpdateTableBuffer also in the configurator, but I put them in the Alt line of the Rules page. When you go to the rules page you will see at the top of the tree view the Alt:. You can set rules here and if you create a new part number in your part master file with the configurator, you can set fields on the newly created part. Here is a sample of some of the rules I have set in the Alt:
Set Field Part.PartDescription = EDITOR1Â Â Â Â (Editor1 is a configurator field that stores the description of my newly created part)
These statements make sure that all configured parts are set to track serial numbers and only whole units are used.
Set Field Part.TrackSerialNum = TRUE
Set Field Part.SNFormat = "x(30)"
Set Field Part.SNBaseDataType = "CHARACTER"
Set Field Part.WholeUnit = TRUE
This one takes a customer price that I calcualte on a page leave statement and drops it into a user defined field on the Order Detail
Call Program lib\UpdateTableBuffer.p(input BUFFER OrderDtl:HANDLE, 'Number01', CustomerPrice)
Sent: Wednesday, November 5, 2008 10:28:02 AM
Subject: RE: [Vantage] Configurator
level on the job.
which goes onto the job in the job Comment section.. It utilizes a
work.
number in from P01.
detail database */
If P01_QUOTENUM< >0 AND GetContextMode( ) = "ORDER" Then Do:
No-Lock No-Error.
IF (OrderDtl.PickListC omment = "") THEN
RUN
lib\UpdateTableBuff er.p
'PickListComment' , P85_ED_JOBCOMMENT) .
ELSE
RUN
'PickListComment' , "Revised: " + P01_CHR_DATETIME + '~n'+
'~n' + OrderDtl.PickListCo mment + '~n'+ '~n' + P85_ED_JOBCOMMENT) .
End.
Paul Millsaps
Time Manufacturing
254.399.2170
paulm@timemfg. com <mailto:paulm@timemfg. com>
intended recipient.
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of wamitch1012
To: vantage@yahoogroups .com
input page.
Many thanks
WAM
We use the following code in the configurator "Page Detail Tab" in the
"Page on Leave" field.
IF QUOTENUMUSE > 0 AND QUOTELINEUSE > 0 THEN DO:
Find QuoteDtl where QuoteDtl.Company = "XE" and QuoteDtl.QuoteNum =
integer(QUOTENUMUSE) and QuoteDtl.QuoteLine =
integer(QUOTELINEUSE) no-lock no-error.
Run lib\UpdateTableBuffer.p(input BUFFER QuoteDtl:HANDLE, 'JobComment',
EdtJobComments).
'QuoteComment',
EdtComments).
Run lib\UpdateTableBuffer.p(input BUFFER QuoteDtl:HANDLE, 'LineDesc',
"CPU Cabinet - " + ChrPartDesSS ).
End.
IF ORDERNUMUSE > 0 AND ORDERLINEUSE > 0 THEN DO:
Find OrderDtl where OrderDtl.Company = "XE" and OrderDtl.OrderNum =
integer(ORDERNUMUSE) and OrderDtl.OrderLine =
integer(ORDERLINEUSE) no-lock no-error.
Run lib\UpdateTableBuffer.p(input BUFFER OrderDtl:HANDLE,
'PickListComment',
EdtJobComments).
'OrderComment',
EdtComments).
'ShipComment',
EdtJobComments).
Run lib\UpdateTableBuffer.p(input BUFFER OrderDtl:HANDLE, 'LineDesc',
End.
/* For Sales Order Comments use these fields:
Sales Order Comment = 'OrderComment'
Job/Picklist Comment = 'PickListComment'
Packing List Comment = 'ShipComment'
Invoice Comment = 'InvoiceComment' */
This successfully populates the Job Comments field and the Comments
fields in both the Quote and the SO, depending where we are entering
the configured line. We have three comments fields in each
configurator. One for entering comments and one each that is not
editable for Jobs and SO comments. These last two are populated from
configuration choices.
DaveH
Xybix
8.03.406 P
> level on the job.
> work.
> number in from P01.
> detail database */
> No-Lock No-Error.
> RUN
> ELSE
> RUN
> End.
> Paul Millsaps
> Time Manufacturing
> 254.399.2170
> intended recipient.
> Of wamitch1012
> input page.
> Many thanks
> WAM
Yeah, I do some similar things. It mainly depends on whether he needs
to see the data on the Sales Order or not. None of the rules will
actually take place until the Job is created. Using the
upddatetablebuffer allows him to see the data on the Sales order before
it gets pushed to a job.
Paul Millsaps
Time Manufacturing
254.399.2170
intended recipient.
Of Steven Gotschall
Sent: Wednesday, November 05, 2008 10:34 AM
Subject: Re: [Vantage] Configurator
Set Field Part.PartDescription = EDITOR1 (Editor1 is a configurator
From: Paul E. Millsaps <paulm@... <mailto:paulm%40timemfg.com> >
level on the job.
work.
number in from P01.
detail database */
No-Lock No-Error.
RUN
ELSE
RUN
End.
Paul Millsaps
Time Manufacturing
254.399.2170
intended recipient.
Behalf
Of wamitch1012
input page.
Many thanks
WAM
I have a configurator set up and have the price for the product coming in wiht the following Code
/* Get Leg 1 Price */
If cmbFirstleg = "ABT2224" then do:
Find First UD14 Where UD14.Company = chrCompany
and UD14.Key1 = " ABT2224"
no-lock no-error.
if Available UD14 then decLeg1 = UD14.Number01.
End.
My questions is this. The cmb box has 3 possible choices in it. In order to get the price for each option I have to run a piece of code for each Choice in the cmbFirstleg.
In the Tech guide it shows that you can use (and UD14.Key1 = cmbFirstleg, but when I tried this it will not bring in any price. It appears that the actual Part number needs to be in the that line of the code.
Is there a way to write something in the code that would pick the actual part number choosen so you don't have to have a line of code pointing to each option?
Thank You
Gene Mack
Does anyone either know or have a trick to set off the configurator button for all items on an order?
Rick
Rick,
I'm not sure what you mean by "set off". Only configurator model parts or parts that were created by a configurator will invoke the configurator button on the order or quote input screen. All non configured items do not apply and have no reference to a configurator. If you configure all items on an order by entering a configurator model first or a previously configured item on each line, then as you select each item on the order the configurator button will be invoked.
Terry Potter
IT Applications Specialist
[MGAMLogo_20thFull.jpg]
206 Wild Basin Road South
Building B, Fourth Floor
Austin, TX 78746
Office: 512.439.3022
Mobile: 512.284.0519
Email: terry.potter@...<mailto:jim.bannerot@...>
CONFIDENTIALITY/DISCLAIMER NOTICE: This email may contain confidential or privileged information and is intended only for the intended recipients. If not the intended recipient, please permanently delete this email and contact the sender. Multimedia Games, Inc. (MGAM) denies any responsibility for any damage arising from the use of email. Any opinion or other statement contained in this email are solely those of their author and do not necessarily represent MGAM
What I would like to do...
I have 10 items on an order that need configured, I would like to click
a button once, and it would run the process for all 10 items.
My Configurator do not ask any questions, it just grabs information form
the header to create the bill of material.
Rick
Of Terry Potter
Sent: Wednesday, March 30, 2011 10:27 AM
Subject: [Vantage] Re: Configurator
Rick,
Terry Potter
Austin, TX 78746
Email: terry.potter@... <mailto:terry.potter%40mm-games.com>
<mailto:jim.bannerot@... <mailto:jim.bannerot%40mm-games.com> >
Effective February 1st a 3% price increase applied to pedestals and lateral files
Effective April 1st a 3% price increase will be applied to all other items.
To view our latest newsletter navigate to: hhttp://www.openplan.com/doc/newsletter/newsletter_OPS_q4_2010.html
To see our new OPS Elevation Seating Line navigate to: http://www.openplan.com/seatingOPS.html
Contact your CSR for discounting information.
Reduce - Reuse - Recycle Buy Open Plan Systems
The content of this message is strictly confidential and is intended for the exclusive use of the addressee. Any unauthorized distribution and copying of this communication is strictly forbidden. If you have received said communication by error, please delete it immediately. HMU, LLC believes that this E-mail and its attachments were free of any virus, worm, Trojan horse, and/or malicious code when sent. However, by reading this message and opening any attachments, the addressee accepts full responsibility for taking protective and remedial action about viruses and other defects.
So what do you do now? Click the configure button, the configurator
opens up and you just click "Save"?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Rick Hagy
Sent: Wednesday, March 30, 2011 10:56 AM
Subject: RE: [Vantage] Re: Configurator
Rick
Behalf
Of Terry Potter
Rick,
Terry Potter
Austin, TX 78746
lateral files
items.
Yes that is correct.
Rick
Of Blake Clemens
Sent: Wednesday, March 30, 2011 11:20 AM
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rick Hagy
Rick
Behalf
Of Terry Potter
Rick,
Terry Potter
Austin, TX 78746
lateral files
items.
The configurator is implemented via business objects like pretty much all of Epicor. You can call the individual pieces via business objects. Depending on where you do the work it can be as simple as just populating the pcinvalues records via the BO. If you are doing actions as part of on-leave statements then you would need to call the on-leave code via the BO. If you are NOT using on-leave statement and all the processing is being done via the method rules you just need to populate the pcinvalues.
Using the BO you could attach the code to a button that would loop through all the lines and for the lines that are configurable you call the logic to run the configurator via BO. The BO adapter is "configuration" not the "Configurator" adapter.
If there are no on-leave logic you would do something like this
GetConfigurationSequence, this gets the configurator dataset, this could contain several "configurators" as Epicor supports cascading configurators. It sounds like this is not the case for you.
If there are cascading configurator you would loop through each one and do the next steps
Next call GetGeneratedConfiguration
You use information from this call to call
GetOrderValues (or QuoteValues)
At this point you have the dataset that you would populate with any pcinvlaues. If your configurator had no controls and no look-up values you wouldn't need to do anything to this dataset other than retrieve it.
Finally you call SaveOrderConfiguration.
At this point there is a fully formed configurator dataset saved in the database. When the get details step is performed during Job creation the method rules will fire.
You would repeat this for each line.
The BL tester is a good way to learn how the business objects work.
This is very high level rough, I can answer any question you have.
Jim Kinneman
Senior Consultant
Encompass Solutions,
> Rick
> Of Blake Clemens
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Behalf
> Of Rick Hagy
> Thanks,
> Rick
> Behalf
> Of Terry Potter
> Rick,
> Terry Potter
> Austin, TX 78746
> lateral files
> items.
Tim
Calvin
> Thanks,
> Tim
> Calvin
> > Thanks,
> > Tim
