Configurator - Help - change pricing
Thanks for the input.
It is working.
Cathy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of aj.rembert@...
Sent: Wednesday, March 05, 2014 8:38 AM
Subject: [Vantage] RE: Configurator - Help - change pricing
I usually make sure the Synchronize Revision Approval is checked just in case. Check to make sure the revision and configurator are approved and, just in case, check to make sure the part's checked in in the Engineering Workbench. If the revision's approved but the configurator isn't, in my experience, it's been because of an error in compiling the configurator. Did you run Test Inputs and Test Rules and they ran without issue?
I went to Configurator Designer to change Input Rules -  click on the option and changed it from $8 to $12.
This is a form change.
Then went to the pricing spreadsheet - changed the option in the spreadsheet from $8 to $12.
I did approve the rev before leaving Configurator. designer.
Now the configure button does is not highlighted and I cannot configure an item.
What did I do wrong?
Is the Part approved?  Both part and configurator have to be approved.  In Epicor 9 you can check the synchronize which will approve both.  If not or if Vantage you have to approve both separately, configurator first then part.
Jim Kinneman
Encompass Solutions, Inc.
