I would check the log files to see if there is an error being thrown.
Also, check the page inputs to see if there aren't any page inputs
active, you have to check the box that says 'Process if no inputs' or
something similar.
Paul Millsaps
Time Manufacturing
254.399.2170
paulm@... <mailto:paulm@...>
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mistransmission.
If you receive this message in error, please immediately delete it and
all copies of it from your system, destroy any hard copies of it and
notify the sender. You must not, directly or indirectly, use, disclose,
distribute, print, or copy any part of this message if you are not the
intended recipient.
Of Blake Clemens
Sent: Wednesday, January 14, 2009 1:36 PM
Subject: [Vantage] Configurator "On-Leaves" Suddenly Stopped Functioning
This question is in regards to the configurator module.
One of our configurators suddenly stopped functioning after lunch today.
The "on-leaves" associated with this configurator will not work. We did
not make any changes to the configurator. If I unapproved the revision
and go into the configurator and perform a "test inputs" it functions as
it should. Does anyone have any ideas why the "on-leaves" suddenly
stopped working?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
***Privileged & Confidential***
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential
information. If received in error, please inform the sender as quickly
as possible and delete this email and any copies. If not an intended
recipient of this email, you must not copy, distribute or rely on it,
and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the
sender and not the views of Delmarva Millwork Corporation.
something similar.
Paul Millsaps
Time Manufacturing
254.399.2170
intended recipient.
Of Blake Clemens
stopped working?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
