Hey Guys,
I have been playing around with the configurator and I seem to have hit a hurdle when including a configured item within another configured item.
Both of these items have been linked to separate configurators and I have added configured item B into A as a sub assembly (and also ensured that pull as assembly was checked)
I was under the impression that doing this would present the user with configurator B before passing the item configured in B to configurator A, then showing configurator A to the user.
However this is not the case, to be able to configure the configurable sub assembly ‘B’ in ‘A’ the user has to via quote add the Item A and get details, then after configuring A, they need to find B inside A’s sub tree and right click this then get details again and finally go through B’s configurator.
This doesn’t seem like its the way its intended to work?
The other thing I have noticed is that in A’s configurator entry screen under the Sequence tab even after clicking Actions > Rebuild Configurator Sequence the Sequence tab is empty, though I thought this would be where I could select what configurator is shown first to the user?
We are using Epicor Version 10.1.500.13
Does anyone have any experience with doing what I am attempting here, Am I missing something, or could this be a bug?
Many Thanks in advance!
Lee
