Configurator
I am not familiar with the configurator -
We have a part that is end of life and is no longer an option
Is there an easy way to disable this option in the configurator so that order entry does not have the ability to use this option?
Hi Cathy,
Yes but how to disable it depends on whether you have a “Super BOM” or “Templated BOM”.
If you have a Super BOM, the part is on a BOM that he configurator picks from and you just have to set the “Keep When” condition to false. If it’s in a drop-down directly, you need to see how it is populated (fixed or code) to remove it.
If it’s a template BOM, then you will have to look through some code to see if it’s in a table or excel sheet to remove the part.
Mark W.
We use Super BOM’s
I will check the code.
Thank you
