Container Receipt Entry - Mass Receipt?
Hi,
We use Container Entry quite a lot on E10 and subsequently have to use Container Receipt Entry when receiving these items. It’s quite a torturous process. Mass receipt works well for most receipts. The warehouse team check the supplier delivery note, check the physical goods and then use Mass Receipt to Select All > Get all (to pull quantities) > Receive all (to mark the receipt lines as received) > Set all to locations (to assign the correct final location/bin of the items) and then hit process. The tabular view of Mass Receipt allows for easy checking, before processing.
Container Receipt is horrible by comparison. There is no mass receipt option. Each line has to be individually flagged as received and the “To Location” button needs to be pressed on each line. What you really want to do, is select the lines which have been received, and then simply confirm to set to all locations and mark as received by the click of a button. It’s kind of what computers are for isn’t it?
Am I missing something or is it really this clunky?
Any help much appreciated,
jDJ
