Context menu inconsistent
I’m trying to figure out what’s different between two different queries in a dashboard that would make the context menus behave differently. Both are pulling the same field from the same table (it’s a UD table with the like values set up) one works, the other does not. It’s a job number.
The one that works has most of the stuff on the top level, which is why I suspect it works. The second has most of the stuff on one sub-query down because of the way I needed to filter the related operation so I could get all of my rows.
Below is the SQL if it helps. It seems like somewhere it just loses it’s like property (in a dashboard, it works fine in the query). But only on the one with the extra level. Do I need to go into the extended attributes in the a BAQ to get them to work again? Looking for PartNum and JobNum to work again in all places in the dashboard.
Any pointers would be appreciated.
Working
    select
    	[UD02].[CreatedAt_c] as [UD02_CreatedAt_c],
    	[UD02].[JobNum_c] as [UD02_JobNum_c],
    	[UD02].[Num_c] as [UD02_Num_c],
    	[UD02].[Key1] as [UD02_Key1],
    	[UD02].[TagNum_c] as [UD02_TagNum_c],
    	[UD02].[UpdatedAt_c] as [UD02_UpdatedAt_c],
    	[UD02].[Weight_c] as [UD02_Weight_c],
    	(EmpBasic.FirstName + ' ' + EmpBasic.LastName) as [Calculated_AddedBy],
    	[UD02].[TruckID_c] as [UD02_TruckID_c],
    	[PartCount].[Calculated_Totalparts] as [Calculated_Totalparts],
    	[PartCount].[Calculated_UniqueNum] as [Calculated_UniqueNum],
    	[UD04].[ShippedAt_c] as [UD04_ShippedAt_c],
    	((case when UD04.ShippedAt_c is not null then  1   else  0  end)) as [Calculated_Shipped],
    	[UD04].[Num_c] as [UD04_Num_c],
    	[UD05].[Text_c] as [UD05_Text_c],
    	[PhotoCount].[Calculated_PhotoCount] as [Calculated_PhotoCount]
    from Ice.UD02 as UD02
    left outer join Ice.UD04 as UD04 on
    	UD02.Company = UD04.Company
    	and UD02.JobNum_c = UD04.JobNum_c
    	and UD02.TruckID_c = UD04.Key1
    left outer join Erp.EmpBasic as EmpBasic on
    	UD02.Company = EmpBasic.Company
    	and UD02.AddedToTruckByEmpID_c = EmpBasic.EmpID
    left outer join  (select
    	[UD03].[Company] as [UD03_Company],
    	[UD03].[LiftID_c] as [UD03_LiftID_c],
    	(sum( UD03.Amount_c )) as [Calculated_Totalparts],
    	(count( UD03.PartNum_c )) as [Calculated_UniqueNum]
    from Ice.UD03 as UD03
    group by [UD03].[Company],
    	[UD03].[LiftID_c])  as PartCount on
    	UD02.Company = PartCount.UD03_Company
    	and UD02.Key1 = PartCount.UD03_LiftID_c
    left outer join Ice.UD05 as UD05 on
    	UD02.Company = UD05.Company
    	and UD02.Key1 = UD05.CommentableID_c
    	and ( UD05.Visibility_c = 'public'  )
    	[UD06].[Company] as [UD06_Company],
    	[UD06].[PhotoableID_c] as [UD06_PhotoableID_c],
    	(count( UD06.Key1 )) as [Calculated_PhotoCount]
    from Ice.UD06 as UD06
    group by [UD06].[Company],
    	[UD06].[PhotoableID_c])  as PhotoCount on
    	UD02.Company = PhotoCount.UD06_Company
    	and UD02.Key1 = PhotoCount.UD06_PhotoableID_c
Not Working
    select
    	[OldTop].[UD03_Amount_c] as [UD03_Amount_c],
    	[OldTop].[UD03_CreatedAt_c] as [UD03_CreatedAt_c],
    	[OldTop].[UD03_EmpID_c] as [UD03_EmpID_c],
    	[OldTop].[UD03_LiftID_c] as [UD03_LiftID_c],
    	[OldTop].[UD03_PartNum_c] as [UD03_PartNum_c],
    	[OldTop].[UD03_PartUOM_c] as [UD03_PartUOM_c],
    	[OldTop].[UD03_UpdatedAt_c] as [UD03_UpdatedAt_c],
    	[OldTop].[UD02_JobNum_c] as [UD02_JobNum_c],
    	[mtlparts].[JobMtl_Company] as [JobMtl_Company],
    	[mtlparts].[JobMtl_JobNum] as [JobMtl_JobNum],
    	[mtlparts].[JobMtl_PartNum] as [JobMtl_PartNum],
    	[mtlparts].[JobOper_OpCode] as [JobOper_OpCode],
    	[OldTop].[Calculated_LiftNum] as [Calculated_LiftNum],
    	[OldTop].[Calculated_Name] as [Calculated_Name],
    	[OldTop].[UD02_Num_c] as [UD02_Num_c],
    	[OldTop].[UD03_Company] as [UD03_Company],
    	[OldTop].[UD04_Num_c] as [UD04_Num_c],
    	[OldTop].[UD05_Text_c] as [UD05_Text_c]
    from  (select
    	[UD03].[Amount_c] as [UD03_Amount_c],
    	[UD03].[CreatedAt_c] as [UD03_CreatedAt_c],
    	[UD03].[EmpID_c] as [UD03_EmpID_c],
    	[UD03].[PartNum_c] as [UD03_PartNum_c],
    	[UD03].[PartUOM_c] as [UD03_PartUOM_c],
    	[UD03].[UpdatedAt_c] as [UD03_UpdatedAt_c],
    	(EmpBasic.FirstName + ' ' + EmpBasic.LastName) as [Calculated_Name],
    	('lift' +' ' + convert(varchar,UD02.Num_c)) as [Calculated_LiftNum],
    	[UD04].[Key1] as [UD04_Key1],
    	[UD05LiftComments].[Text_c] as [UD05LiftComments_Text_c]
    inner join Erp.EmpBasic as EmpBasic on
    	UD03.Company = EmpBasic.Company
    	and UD03.EmpID_c = EmpBasic.EmpID
    inner join Ice.UD02 as UD02 on
    	UD03.Company = UD02.Company
    	and UD03.LiftID_c = UD02.Key1
    left outer join Ice.UD05 as UD05LiftComments on
    	UD02.Company = UD05LiftComments.Company
    	and UD02.Key1 = UD05LiftComments.CommentableID_c
    	UD03.Company = UD05.Company
    	and UD03.Key1 = UD05.CommentableID_c)  as OldTop
    	[JobMtl].[Company] as [JobMtl_Company],
    	[JobMtl].[JobNum] as [JobMtl_JobNum],
    	[JobMtl].[PartNum] as [JobMtl_PartNum],
    	[JobOper].[OpCode] as [JobOper_OpCode]
    from Erp.JobMtl as JobMtl
    inner join Erp.JobAsmbl as JobAsmbl1 on
    	JobMtl.Company = JobAsmbl1.Company
    	and JobMtl.JobNum = JobAsmbl1.JobNum
    	and JobMtl.AssemblySeq = JobAsmbl1.AssemblySeq
    inner join Erp.JobOper as JobOper on
    	JobMtl.JobNum = JobOper.JobNum
    	and JobMtl.AssemblySeq = JobOper.AssemblySeq
    	and JobMtl.RelatedOperation = JobOper.OprSeq
    	and
    	JobAsmbl1.Company = JobOper.Company
    	and JobAsmbl1.JobNum = JobOper.JobNum
    	and JobAsmbl1.AssemblySeq = JobOper.AssemblySeq
    union
    select
    	[JobAsmbl].[Company] as [JobAsmbl_Company],
    	[JobAsmbl].[JobNum] as [JobAsmbl_JobNum],
    	[JobAsmbl].[PartNum] as [JobAsmbl_PartNum],
    	[JobOper1].[OpCode] as [JobOper1_OpCode]
    from Erp.JobAsmbl as JobAsmbl
    inner join Erp.JobOper as JobOper1 on
    	JobAsmbl.Company = JobOper1.Company
    	and JobAsmbl.JobNum = JobOper1.JobNum
    	and JobAsmbl.Parent = JobOper1.AssemblySeq
    	and JobAsmbl.RelatedOperation = JobOper1.OprSeq)  as mtlparts on
    	OldTop.UD03_Company = mtlparts.JobMtl_Company
    	and OldTop.UD03_PartNum_c = mtlparts.JobMtl_PartNum
    	and OldTop.UD02_JobNum_c = mtlparts.JobMtl_JobNum
    	and ( mtlparts.JobOper_OpCode = 'ASSY'  )
