Does anyone know how to control the colors on a chart better than the options given to you in the properties? The colors that they give are really hard to see, and they change every time you refresh. I would like to set them to bold primary and secondary colors and have them stay the same so people can get used to seeing the same colors on the chart. I briefly looked in customization but didn’t see anything built in. I’m assuming that I’ll need some code, if someone could point me in the right direction to start that would be helpful. (I’m guessing though that I may just be out of luck…)
Did you ever find a way? Is there something other than random? Right now, all I get is pastels…
Thanks, Eric
I did not. Random was the best I could get. EDD it probably going to be a better replacement eventually anyways.
