Convert String to Date
This should work, just replace "sDate" with the field that you want
to convert:
date(tonumber(left(sDate,4)),tonumber(mid(sDate,5,2)),tonumber(mid
(sDate,7,2)))
Linda Lowney
Decoustics Limited
--- In vantage@yahoogroups.com, Dan Shallbetter <dans@s...> wrote:
> Gary,
> What field is it? Do a browse on the field it should tell you the
field
> type. You might need to change the format to YYYY,MM,DD for the
DateValue
> function to work.
> Dan Shallbetter
> States Electric Mfg.
> -----Original Message-----
> From: Gary Wassing [mailto:gwassing@s...]
> Sent: Wednesday, October 22, 2003 12:29 PM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] Re: Convert String to Date
> I've tried the isDate and it comes back false. The format is
yyyymmdd.
> cDate returns bad date format string.
> Gary Wassing
> MIS
> SteelCraft Industries
> 519-271-4750 x227
> From: Brian Stenglein [mailto:bstenglein@c...]
> Sent: Wednesday, October 22, 2003 1:17 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Convert String to Date
> You can also use the CDate function to simply convert the data type
> from string to date, if that is what you want.
> Brian Stenglein
> Clow Stamping Co.
> --- In vantage@yahoogroups.com, Gary Wassing <gwassing@s...> wrote:
> > Is there any way in Crystal 8.5 to convert a string field to a
date
> field.
> > Gary Wassing
> > MIS
> > 519-271-4750 x227
must have
Builder and
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> <http://docs.yahoo.com/info/terms/>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=194081.4074964.5287182.1261774/D=egroupweb/S=17
050071
> 83:HM/A=1732163/R=0/SIG=11n0nglqg/*http://www.ediets.com/start.cfm?
code=3051
> 0&media=zone> click here
> <http://us.adserver.yahoo.com/l?
M=194081.4074964.5287182.1261774/D=egroupmai
> l/S=:HM/A=1732163/rand=867666485>
must have
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
Is there any way in Crystal 8.5 to convert a string field to a date field.
Gary Wassing
MIS
519-271-4750 x227
Gary,
Read the help on DateValue
Dan Shallbetter
Sent: Wednesday, October 22, 2003 10:41 AM
Subject: [Vantage] Convert String to Date
Gary Wassing
MIS
519-271-4750 x227
Gary,
From Crystal Help:
Action
DateValue (string) returns a Date value given a string that represents a
date from January 1, 100 through December 31, 9999.
DateValue (number) returns a Date value given a number of days starting from
December 30, 1899. Number can be positive or negative, and truncated if
fractional.
DateValue (dateTime) returns the date portion of a given DateTime value.
DateValue (YYYY, MM, DD) returns a Date value given numeric arguments of the
year, month and day.
Examples
The following examples are applicable to both Basic and Crystal syntax:
DateValue ("Dec 31, 1999")
Returns the Date value for Dec. 31, 1999.
DateValue (50)
Returns the Date value for February 18, 1900.
DateValue (#Oct. 20, 1999 12:02pm#)
Returns the Date value for October 20, 1999.
DateValue (1930, 7, 30)
Returns the Date value for July 30, 1930.
Comments
You can use the IsDate function to check if a String argument can be
converted to a Date before doing the actual conversion. That way, if the
conversion cannot be done, you can handle the situation appropriately.
Troy
Sent: Wednesday, October 22, 2003 11:41 AM
Gary Wassing
MIS
519-271-4750 x227
Brian Stenglein
Clow Stamping Co.
field.
> Gary Wassing
> MIS
> 519-271-4750 x227
I've tried the isDate and it comes back false. The format is yyyymmdd.
Gary Wassing
MIS
519-271-4750 x227
Brian Stenglein
Clow Stamping Co.
field.
> Gary Wassing
> MIS
> 519-271-4750 x227
Gary,
What field is it? Do a browse on the field it should tell you the field
type. You might need to change the format to YYYY,MM,DD for the DateValue
function to work.
Dan Shallbetter
Gary Wassing
MIS
519-271-4750 x227
Brian Stenglein
Clow Stamping Co.
field.
> Gary Wassing
> MIS
> 519-271-4750 x227
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.4074964.5287182.1261774/D=egroupweb/S=17050071
83:HM/A=1732163/R=0/SIG=11n0nglqg/*http://www.ediets.com/start.cfm?code=3051
<http://us.adserver.yahoo.com/l?M=194081.4074964.5287182.1261774/D=egroupmai
You could use some "instr" functions to switch the string around to get it
into the correct format.
Troy Funte
Sent: Wednesday, October 22, 2003 1:45 PM
Gary,
function to work.
Dan Shallbetter
Gary Wassing
MIS
519-271-4750 x227
Brian Stenglein
Clow Stamping Co.
field.
> Gary Wassing
> MIS
> 519-271-4750 x227
have
ADVERTISEMENT
have
ADVERTISEMENT
