Converting from 4.0 to 5.0 and then to 5.1
Jumping Versions. I highly advise that you follow ALL the steps outlined in
the install documents for each version. And practice what you want to do
before you do it. Think of it as a long term investment because it will
save you problems in the future.
Shirley
Sent: Friday, July 26, 2002 5:30 PM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: Re:RE: [Vantage] Converting from 4.0 to 5.0 and then to 5.1
fyi, i tried to "cheat" for this same conversion process. I was told I
could
install progress 9.1C since 5.0 would run under 9.1C as well as 9.1A. I
was
basically trying to skip one of the install steps. Long story short, my
'short
cut' cost me an evening.
Moral of the story...do your conversions per the instructions for the best
results. Unless you have lots of time to tinker that is...
My 3 cents for the day.
Mike Lowe
Connor Manufacturing Services
____________________Reply Separator____________________
Subject: RE: [Vantage] Converting from 4.0 to 5.0 and then to 5.1
Author: <vantage@yahoogroups.com>
Date: 7/26/2002 1:39 PM
I believe you only have to put on the LATEST 5.0 patch and database
conversions before you move on to 5.1. That's how I did it when I
migrated
from 4.0 to 5.0 to 5.1. Tech support can tell you for sure, but I think
the
patches are "inclusive." You have to bring the database up in 5.0
anyhow -
run your accounting reports to be sure everything matches, so you might as
well use the latest patch.
Lydia
Sent: Friday, July 26, 2002 1:09 PM
Subject: [Vantage] Converting from 4.0 to 5.0 and then to 5.1
i was wondering if it is possible to convert from 4.0 to 5.0
and then to 5.1 without putting the 5.0 patches on before
going to 5.1.
have
have
Received: from alv-web1.alvaka.net [207.213.32.80] by
la-smtpg.connorms.com (ccMail Link to SMTP R8.31.00.5)
; Fri, 26 Jul 2002 13:36:17 -0700
Return-Path:
<sentto-20369-32789-1027716055-MLowe=connorms.com@...>
Received: from n31.grp.scd.yahoo.com ([66.218.66.99])
by alv-web1.alvaka.net (NAVGW 2.5.1.12) with SMTP id M2002072613420602022
for <MLowe@...>; Fri, 26 Jul 2002 13:42:11 -0700
X-eGroups-Return:
Received: from [66.218.67.193] by n31.grp.scd.yahoo.com with NNFMP; 26 Jul
2002 20:40:56 -0000
X-Sender: Lcoffman@...
X-Apparently-To: vantage@yahoogroups.com
Received: (EGP: mail-8_0_7_4); 26 Jul 2002 20:40:55 -0000
Received: (qmail 1917 invoked from network); 26 Jul 2002 20:40:54 -0000
Received: from unknown (66.218.66.216)
by m11.grp.scd.yahoo.com with QMQP; 26 Jul 2002 20:40:54 -0000
Received: from unknown (HELO cep?exc.pacbell.net) (64.172.91.162)
by mta1.grp.scd.yahoo.com with SMTP; 26 Jul 2002 20:40:54 -0000
Received: by CEP_EXC with Internet Mail Service (5.5.2650.21)
id <3CXZ4MJW>; Fri, 26 Jul 2002 13:39:31 -0700
Message-ID: <6334FCC77BAED31190A200A0C9FC057023BBAA@CEP_EXC>
X-Mailer: Internet Mail Service (5.5.2650.21)
X-Yahoo-Profile: lcoffman2001
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact
vantage-owner@yahoogroups.com
Delivered-To: mailing list vantage@yahoogroups.com
Precedence: bulk
List-Unsubscribe: <mailto:vantage-unsubscribe@yahoogroups.com>
Date: Fri, 26 Jul 2002 13:39:28 -0700
Reply-To: vantage@yahoogroups.com
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Yahoo! Groups Sponsor
ADVERTISEMENT
fyi, i tried to "cheat" for this same conversion process. I was told I could
install progress 9.1C since 5.0 would run under 9.1C as well as 9.1A. I was
basically trying to skip one of the install steps. Long story short, my 'short
Mike Lowe
conversions before you move on to 5.1. That's how I did it when I migrated
from 4.0 to 5.0 to 5.1. Tech support can tell you for sure, but I think the
patches are "inclusive." You have to bring the database up in 5.0 anyhow -
Lydia
going to 5.1.
Received: from alv-web1.alvaka.net [207.213.32.80] by la-smtpg.connorms.com (ccMail Link to SMTP R8.31.00.5)
Return-Path: <sentto-20369-32789-1027716055-MLowe=connorms.com@...>
X-eGroups-Return: sentto-20369-32789-1027716055-MLowe=connorms.com@...
Received: from [66.218.67.193] by n31.grp.scd.yahoo.com with NNFMP; 26 Jul 2002 20:40:56 -0000
MIME-Version: 1.0
Mailing-List: list vantage@yahoogroups.com; contact vantage-owner@yahoogroups.com
Precedence: bulk
