Not to my knowledge.
You could export the customization, edit the XML and reimport it into the
other area. That might work. Or it might just hose it up.
You can copy/paste the code though and only have to recreate the controls.
As long as they're named the same and you have the right references, it
should work with little if any tweaking.
What do you need to do?
On Wed, Mar 16, 2011 at 11:03 AM, Richard <rgraf@...> wrote:
> Good morning all you Vantage experts!
> Is it possible to copy an entire sheet from one customization to another?
> It would simplify a couple of my customizations tremendously. Thanks in
> advance for all the help.
> Rick
