Correct Path Syntax for publishing ODBC Crystal report
What version of Vantage or you on?
We used to use "\\YourServerName\PathToYourReport\ReportName.rpt" Then last
weekend I installed 408b, and after that this wouldn't work anymore. I had
to move all of the files and change all of the paths to
"/CustomReports/ReportName.rpt" which is the folder located in
"\\SERVERNAME\epicor\mfgsys803\Server\reports\".
I have an open call with Epicor about this, but I haven't gotten anywhere.
The tech has tried to say the system is designed to work this way. However,
for the last 4 years I've done it using the UNC path of a folder on the
server and all was fine. Actually, according to the directions Epicor sent
me, this is how they tell you to do it as well (See Below, Step 10).
Hope this helps,
Norman Hutchins
Network Administrator
Howell Laboratories, Inc.
Shively Labs
207-647-3327
Summary: CR "Auto load error" and "Application Load error"
printing
Crystal Reports
Book: Support Solutions
Page: 5140MPS
PROBLEM DESCRIPTION: Printing or previewing any XML style reports fails
with the error "Application Load error" or an "Auto load error" in the
System Monitor. There may also be a "Load Report Failed" message.
May also have the message "System cannot find the path specified.
Inner
stack trace."
May be while trying to run a custom Crystal report that has been added
to
the menu via Menu Maintenance. This may also occur for a standard
Crystal
Report, though that is rare.
PROBLEM RESOLUTION: There are several reasons for these error messages.
Check the following:
1. Go to System Management->Utilities->System Agent. Look at the
Client
Program Directory. It probably has a physical path; try changing it to
a
UNC. Crystal reports should now print.
Example:
\\servername\epicor\MfgSys80\Server
<file:///\\servername\epicor\MfgSys80\Server>
CLOSELY LOOK AT THE SPELLING. "Server" is spelled "Sever". And that's
just not going to work.
2. Go to System Management->Utilities->System Agent. Check the System
AppServer URL, and make certain the server name and port number are
correct
for this AppServer. This can be checked in the Progress Explorer Tool.
3. User needs to have full control over the file to open and print it.
4. If this is a custom Crystal Report, added as a Vantage menu: Go
into
System Management > Security Maintenance > Menu Maintenance and navigate
to
the report menu item in question. Look at the Report Path field. This
value should just be something like
\\ServerName\CustomReports\MyCustomReport.rpt
<file:///\\ServerName\CustomReports\MyCustomReport.rpt> .
5. Go to System Management->Company Maintenance->Report Style
Maintenance,
and select the problem report in the tree on the left. Then select
the
Standard style below it. On the right side, for the company you are
logged into, check the Valid and Default boxes.
6. Go into System Management > Security Maintenance > Menu Maintenance
and
navigate to the report menu item in question. Look at the Report Path
field. This value should just be something like
7. Make certain the file name is not too long. If necessary, change
the
actual report name to an 8.3 format, like PackTest.rpt. Also make sure
that
the report name itself does not contain spaces like "Custom Report.rpt".
It
should be CustomReport.rpt.
8. In the Properties for the TaskAgent and ProcessServer AppServers,
there
cannot be an entry for PROPATH the points to a \reports folder before
the
path to \epicor\mfgsys80\server\reports (or mfgsys803\reports).
9. If this occurring on Terminal Server or Citrix clients, but LAN
clients
can print fine, see document 8648MPS.
10. Older functionality in menu maintenance had you add a '-r
\\ServerName\CustomReports\MyReport.rpt
<file:///\\ServerName\CustomReports\MyReport.rpt> ' parameter. The new
functionality
assumes the -r if the program type is Custom Report link. You just need
to
provide the path include the report file name. There is no need for the
-r
parameter anymore.
11. As of patch VN 8.00.802, make certain the Crystal Reports X Runtime
is
installed on this client. These are perquisites necessary on any
Vantage
client that will be printing Crystal Reports forms. If they are
installed,
they will be listed under the Add/Remove Programs Control Panel.
There have been instances where the Crystal X Runtime has not completely
un-installed, and is still visible in the Windows add\remove programs
list.
Check that it is no longer there before attempting a reinstall of the
Crystal X Runtime. Reboot the pc after the app does not appear in the
add\remove programs list. Reinstall the Crystal X Runtime, and when
installing, select install for "all users" option during setup.
12. As of patch VN 8.00.803, make certain the Crystal Report XI Runtime
is
installed on this client. These are prerequisites necessary on any
Vantage
installed,
There have been instances where the Crystal XI Runtime has not
completely
list.
Crystal XI Runtime. Reboot the pc after the app does not appear in the
add\remove programs list. Reinstall the Crystal XI Runtime, and when
13. As of patch VN 8.00.808, make certain the Crystal Report XI R2
Runtime
is installed on this client. These are prerequisites necessary on any
Vantage client that will be printing Crystal Reports forms. If they are
installed, they will be listed under the Add/Remove Programs Control
Panel.
There have been instances where the Crystal XI R2 Runtime has not
completely
list.
Crystal XI R2 Runtime. Reboot the pc after the app does not appear in
the
add\remove programs list. Reinstall the Crystal XI R2 Runtime, and when
Hi, I am trying to publish a working crystal report in menu maintenance on 8.03.305K
However, when I run it up (after saving, closing and re-opening Vantage) I get the message below:
I have tried local and url paths but get the same error.
Where should I locate the report and what is the correct path syntax??
Error Message indicates a path issue -
Load report failed.
Stack Trace
at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.EnsureDocumentIsOpened()
at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod, Int16 parentJob)
at CrystalDecisions.CrystalReports.Engine.ReportDocument.Load(String filename, OpenReportMethod openMethod)
at Epicor.Mfg.Lib.Report.EpiCrystalViewer..ctor(String rptFile, String usr, String passwd, String rTitle)
at Epicor.Mfg.UI.App.CustomReportEntry.Transaction.previewReport()
Inner Exception
The filename, directory name, or volume label syntax is incorrect.
Inner Stack Trace
at CrystalDecisions.ReportAppServer.ClientDoc.ReportClientDocumentClass.Open(Object& DocumentPath, Int32 Options)
at CrystalDecisions.ReportAppServer.ReportClientDocumentWrapper.Open(Object& DocumentPath, Int32 Options)
Hi,
Try this:
<file:///\\YourServerName\PathToYourReport\ReportName.rpt>
Regards,
Linda
Of sbser2000
Sent: Wednesday, December 09, 2009 6:53 AM
Subject: [Vantage] Correct Path Syntax for publishing ODBC Crystal
report
on 8.03.305K
Load report failed.
Stack Trace
at
entIsOpened()
Inner Exception
Inner Stack Trace
at
at
at
entIsOpened()
