Your symptoms point to a problem with your customized job travler.
If the database was corrupt it's very unlikely that vantage would
display your data properly and ODBC wouldn't. Check the travler
first. If you can't get it then repost. There are a couple of
maintenance tools for the database you can try but I doubt they will
help and you'll have to shutdown Vantage to use them.
--- In vantage@y..., "vtaeroman" <brento@v...> wrote:
> Does anyone know where I go to access any utilities to test whether
> our Vantage database is corrupted?
> It looks like we are getting unpredictable results with our
> customized job traveler that uses ODBC to pull in a few fields.
> Depending on the job, sometimes the information is displayed
> correctly but usually there are some fields missing. We can see
the
> data in the fields by looking at the job in Vantage but the
traveler
> just doesn't always display the data.
> Any help would be appreciated.
> Brent O'Donnell
