Is anyone running CorVu on a Windows 10 machine? We have it installed on Win10 but a user is not able to edit queries. We’re wondering if this is a Windows 10 issue or CorVu permissions.
Does the user’s corvu.ini file have the proper license codes to be able to edit queries?
The actual ini file being used by the program……
The license code is valid to edit in Win7 but maybe not in Win10. We thought it might have been a write access to the corvu.ini file but even with access to write to the .ini file, it still does not allow the user to edit.
I had to find the corvu.ini file under user appdata – (it is hidden pretty deeply) and delete it so that the ini file in C:\Windows was used
So is it pointing to the incorrect ‘appdata’ .ini file which needs to be deleted first? I’m wondering if this was done on Win7 during the install and was not done on Win10?
Interesting…we did this and it worked. Any thoughts as to why it needs to be deleted from the appdata folder location? Wondering if this needs to be included in the install procedure.
