Hello,
I have an urgent problem. when finance post the cost/wip, we got the following message. do you know why we get that.
thanks,
Eddy
The [2].“Details–Is Reverted” value is not found.
The [2].“Details–Base Cost Method” value is not found.
Hello,
thanks,
Eddy
Go into GL Transaction type -
Select COSandWIP rule
Turn on Logging
Run the inventory WIP Reconciliation report
Narrow down to day and transaction to determine which part is causing problem.
Sounds like you have record with no value causing the issue.
Review the PElog to review issue as you go.
When you are done, turn off logging - it slows down the processing of the report and capture.
thanks. we fixed the issue
Out of interest what was it?
