CPQ - Determining Rule Runtime Duration
Greetings,
I remember reading an article somewhere about a method of logging / displaying the time (in ms) that a CPQ rule takes to run, but I could not find any record of this in zendesk or in the tech ref guides.
Where is this information located or how can I determine how long a rule takes to run?
(I want to identify which rules are taking “too long” to run or which need optimization.)
Alex
I am embarking on a project to make our CPQs run faster so this would be useful to me as well.
Method 3 looks similar to what I remember, but it is not as detailed as I would like.
(there was some way of timing every rule and outputting the runtime regardless of it’s use)
Epicor closed the previous ticket after they were unable to locate the information linked above–I have since reopened it, supplied the link, and await a response regarding server-side tracing or accessing additional information.
On the Kinetic side, you can check which BOs are taking the longest, but that’s more of a confirmation than anything:
