John, I played with this today and found a way but it's not pretty and it
works with text obects only (labels), not fields.
Here what I did:
Insert a text object, type each character followed by ENTER until you are
done. Select Format->Format Text, on the Common page, check the "Can Grow"
box and indicate the maximum lines to grow (0 for no maximum). To improve
the look, select "Centered" as the Horizontal Alignment. Now the bad news.
When you do this, Crystal will change the line height to match the text
pbject and can really foul up your formatting. Hope htis helps.
Jim Stetter
From: Hiatt Manufacturing, Inc. [mailto:hiattmfg@...]
Sent: Tuesday, December 05, 2000 1:00 PM
To: vantage@egroups.com
Subject: [Vantage] RE: CR Shipping Labels
Thanks Jim, that did it. Do you by chance know if CR lets you rotate text
90° so it runs up & down instead of across?
John Mueske
Hiatt Manufactuirng, Inc.
SBS 4.5 - Vantage 3.00.632
Here what I did:
Jim Stetter
John Mueske
