Create a new EpiDataView
Not exactly. ARTrackerTot is the parent with CustomerList and InvcHead as children linked by CustNum. CustomerList and InvcHead are also generated using business objects. Nothing is directly linked to any Vantage tables, just business object calls.
Â
If it makes it any easier. Lets start with the customer form and link the ARTrackerTot to the Customer EpiDataView. This would give me a good starting point.
To: Steven Gotschall <sgotschall@...>
Cc: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Friday, July 8, 2011 2:37 PM
Subject: Re: [Vantage] Create a new EpiDataView
Â
So to be clear you want ARTrackerTot as a shild EpiView of UD08?
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Fri, Jul 8, 2011 at 2:34 PM, Steven Gotschall <sgotschall@...>wrote:
> I'm using the UD08 form, but I am not using the UD08 Table. ARAgingTrackerAdapter
> returns a dataset with a table called ARTrackerTot. The key field in
> ARTrackerTot is CustNum.
> *From:* Jose Gomez <jose@...>
> *To:* Steven Gotschall <sgotschall@...>
> *Cc:* "vantage@yahoogroups.com" <vantage@yahoogroups.com>
> *Sent:* Friday, July 8, 2011 2:14 PM
> *Subject:* Re: [Vantage] Create a new EpiDataView
> Which Form are you doing this on, so that I can generate code which will be
> pertinent, and which Fields are you going to use as Key
> Thanks!
> *Jose C Gomez*
> *Software Engineer*
> *checkout my new blog <http://www.usdoingstuff.com/> *
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
> On Fri, Jul 8, 2011 at 1:51 PM, Steven Gotschall <sgotschall@...>wrote:
> A would appreciate the 9 code. I can't always use a FKV. For example I
> have a form that calls the ARAgingTrackerAdapter (not possible as a FKV) and
> assigns it to an EpiUltraGrid. I would like to create an EpiDataView for
> this and assign it to the form so that other fields on the form can be
> updated as you scroll though the aging data. I do it now through code, but
> its messy.
> *To:* vantage@yahoogroups.com
> *Sent:* Friday, July 8, 2011 9:04 AM
> That is actually a built in feature of Epicor 9.05 in 803 you may be
> better
> off just adding a FKV.
> If you insist in having an EpiDataView then let me know and I'll generate
> 9
> code which youncan then adjust to fit 803
> *Jose C Gomez*
> Software Engineer
> E: jose@...
> On Fri, Jul 8, 2011 at 8:50 AM, Steven <sgotschall@...> wrote:
> > Vantage 8.03.408A Progress
> > Does anyone know how to create a new EpiDataView from within a
> > Customization? What I want to do is call a BO, assign the returned
> dataset
> > to an UltraGrid and then create an EpiDataview which I can assign to the
> > form. Once recognized by the form I can then create other controls on the
> > form and assign them to fields in the EpiDataView.
> > Thanks in advance.
> > Steven G.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Does anyone know how to create a new EpiDataView from within a Customization? What I want to do is call a BO, assign the returned dataset to an UltraGrid and then create an EpiDataview which I can assign to the form. Once recognized by the form I can then create other controls on the form and assign them to fields in the EpiDataView.
Thanks in advance.
Steven G.
That is actually a built in feature of Epicor 9.05 in 803 you may be better
If you insist in having an EpiDataView then let me know and I'll generate 9
*Jose C Gomez*
Software Engineer
E: jose@...
> Thanks in advance.
> Steven G.
Jose,
Is there any documentation on creating a new epidataview in 905?
Jose Gomez
Sent: Friday, July 08, 2011 9:05 AM
*Jose C Gomez*
Software Engineer
E: jose@...
> Thanks in advance.
> Steven G.
No,
Go to Tools -> Wizard -> Add UDF Child
Select whatever in there (doesn't matter as long as you are tryin to use a
different table)
once you hit finish, it will generate 100+ lines of code
Then replace all UDF references with references to the right tables /
adapters
works like a charm.
*Jose C Gomez*
Software Engineer
E: jose@...
On Fri, Jul 8, 2011 at 11:06 AM, Kevin Simon <ksimon@...> wrote:
> Jose,
> Of
> Jose Gomez
> *Jose C Gomez*
> Software Engineer
> E: jose@...
> dataset
> > Thanks in advance.
> > Steven G.
A would appreciate the 9 code. I can't always use a FKV. For example I have a form that calls the ARAgingTrackerAdapter (not possible as a FKV) and assigns it to an EpiUltraGrid. I would like to create an EpiDataView for this and assign it to the form so that other fields on the form can be updated as you scroll though the aging data. I do it now through code, but its messy.
Sent: Friday, July 8, 2011 9:04 AM
*Jose C Gomez*
Software Engineer
E: jose@...
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
> Thanks in advance.
> Steven G.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Thanks!
*Jose C Gomez*
*Software Engineer*
E: jose@...
> its messy.
> better
> 9
> *Jose C Gomez*
> Software Engineer
> E: jose@...
> dataset
> > Thanks in advance.
> > Steven G.
I'm using the UD08 form, but I am not using the UD08 Table. ARAgingTrackerAdapter returns a dataset with a table called ARTrackerTot. The key field in ARTrackerTot is CustNum.
Sent: Friday, July 8, 2011 2:14 PM
Which Form are you doing this on, so that I can generate code which will be pertinent, and which Fields are you going to use as Key
Thanks!
Jose C Gomez
Software Engineer
checkout my new blogÂ
E: jose@...
     Â
>From: Jose Gomez <jose@...>
>*Jose C Gomez*
>Software Engineer
>E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
>> Thanks in advance.
>> Steven G.
>>Â
>Â Â http://groups.yahoo.com/group/vantage/
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Thanks!
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> its messy.
> better
> 9
> *Jose C Gomez*
> Software Engineer
> E: jose@...
> dataset
> > Thanks in advance.
> > Steven G.
