Wow, that is simple enough. Thanks a lot. Didn't even notice that button there. I was just a button away.
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> In the BAQ Designer, click the little button with a strange picture and a tooltip of “Show User Defined Fieldsâ€Â, usually to the right of the A->Z sort button. Otherwise the designer hides all the CheckBox01 etc fields on you.
> Brian.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Drew
> Sent: Tuesday, April 17, 2012 4:53 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Create Field to report on a BAQ
> Thanks for the reply. I did select "Part.CheckBox01" on the EpiBinding row, but when I pull "Part" into my BAQ, it does not have a checkbox01 column to select. Do I have to make it visible somewhere else?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic Drecchio" <vic.drecchio@> wrote:
> > Andrew,
> > If you bound your control within Customization to a table’s field, then that’s all you need. That value will now update Part.Checkbox01 (assuming you selected that field when you customized your form).
> > Then, simply create a BAQ or modify other Report Data Def’s to include your field in various reports.
> > From: Drew
> > Sent: Tuesday, April 17, 2012 4:12 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Create Field to report on a BAQ
> > I have created a Check box on my Part Entry screen to suggest if something needs to go to inspection or not. I am new to Epicor and don't know how to map it so it is a reportable field. For example, if I wanted to pull that check box into a BAQ for reporting. I see the EpiBinding and I have selected CheckBox01, but how do I add it to "Part" so I can query it into my BAQ and how do I rename that field to say what I want it to say?
> > is this done by creating a UD Table?
> > I hope I was clear in what I want to do.
> > Thanks,
> > Andrew
> > No virus found in this message.
> > Checked by AVG - www.avg.com
> > Version: 2012.0.1913 / Virus Database: 2411/4942 - Release Date: 04/17/12
