<div id="ygrps-yiv-1897420718yiv8494975632ygrp-text">
<div>Kim,<br clear="none">Link your search adapter and then call the search from your button click. Here is one for a job search:<br clear="none"><br clear="none"> private void btnJobNum_Click(object sender, System.EventArgs args)<br clear="none"> {<br clear="none"> // ** Place Event Handling Code Here **<br clear="none"><br clear="none"> // Job Number selection<br clear="none"> SearchOnJobEntryAdapterShowDialog(); <br clear="none"> <br clear="none"> }<br clear="none"><br clear="none"> private void SearchOnJobEntryAdapterShowDialog()<br clear="none"> {<br clear="none"> // Wizard Generated Search Method<br clear="none"> // You will need to call
this method from another method in custom code
// For example, [Form]_Load or [Button]_Click
bool recSelected;
string whereClause = string.Empty;
System.Data.DataSet dsJobEntryAdapter = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "JobEntryAdapter", out recSelected, true, whereClause);
if (recSelected)
System.Data.DataRow adapterRow = dsJobEntryAdapter.Tables[0].Rows[0];
// Map Search Fields to Application Fields
EpiDataView edvCallContextBpmData = ((EpiDataView)(this.oTrans.EpiDataViews["CallContextBpmData"]));
System.Data.DataRow edvCallContextBpmDataRow = edvCallContextBpmData.CurrentDataRow;
if ((edvCallContextBpmDataRow != null))
edvCallContextBpmDataRow.BeginEdit();
edvCallContextBpmDataRow["ShortChar01"] = adapterRow["JobNum"];
edvCallContextBpmDataRow["Character03"] = adapterRow["PartNum"];
//edvCallContextBpmDataRow["ShortChar02"] = "0";
//edvCallContextBpmDataRow["Character04"] = adapterRow["PartNum"];
//edvCallContextBpmDataRow["Character02"] = "0";
edvCallContextBpmDataRow.EndEdit();
grpForms.Enabled=true;
btnAssembly.Enabled=true;
//txtAssemblySeq.Enabled=true;
</div>
<div style="height:0px;color:rgb(255, 255, 255);"></div></div>
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632 --
#ygrps-yiv-1897420718yiv8494975632ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp #ygrps-yiv-1897420718yiv8494975632hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp #ygrps-yiv-1897420718yiv8494975632ads {
margin-bottom:10px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp .ygrps-yiv-1897420718yiv8494975632ad {
padding:0 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp .ygrps-yiv-1897420718yiv8494975632ad p {
margin:0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mkp .ygrps-yiv-1897420718yiv8494975632ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ygrp-lc #ygrps-yiv-1897420718yiv8494975632hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ygrp-lc .ygrps-yiv-1897420718yiv8494975632ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity span {
font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity span span {
color:#ff7900;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632activity span .ygrps-yiv-1897420718yiv8494975632underline {
text-decoration:underline;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632attach div a {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632attach label a {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632bold a {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 dd.ygrps-yiv-1897420718yiv8494975632last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 dd.ygrps-yiv-1897420718yiv8494975632last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 dd.ygrps-yiv-1897420718yiv8494975632last p span.ygrps-yiv-1897420718yiv8494975632yshortcuts {
margin-right:0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632attach-table div div a {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632attach-table {
width:400px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632file-title a, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632file-title a:active, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632file-title a:hover, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632file-title a:visited {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632photo-title a, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632photo-title a:active, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632photo-title a:hover, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div.ygrps-yiv-1897420718yiv8494975632photo-title a:visited {
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 div#ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg #ygrps-yiv-1897420718yiv8494975632ygrp-msg p a span.ygrps-yiv-1897420718yiv8494975632yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632green {
color:#628c2a;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 o {
font-size:0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632photos div {
float:left;width:72px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632reco-category {
font-size:77%;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632reco-desc {
font-size:77%;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 .ygrps-yiv-1897420718yiv8494975632replbq {
margin:4px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg select, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 input, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg pre, #ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 code {
font:115% monospace;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-mlmsg #ygrps-yiv-1897420718yiv8494975632logo {
padding-bottom:10px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-msg p#ygrps-yiv-1897420718yiv8494975632attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-reco #ygrps-yiv-1897420718yiv8494975632reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-sponsor #ygrps-yiv-1897420718yiv8494975632ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1897420718 #ygrps-yiv-1897420718yiv8494975632 #ygrps-yiv-1897420718yiv8494975632ygrp-vital ul li:last-child {
border-right:none !important;}
