Probably the simplest way would be pre-processing method directive on Customer Update.
Add an action and pick execute ABL code. Then enter the code below and change for your group id and description.
There are samples of these in the ICE Tools that are EpicWeb. EpicorICETools_UserGuide_905700.pdf is in the documentation section of 700, there is probably one for 702.
Greg Payne
For Each ttCustomer where ttCustomer.RowMod ='U' and ttCustomer.GroupCode =''.
If substring(ttCustomer.CustID,1,1) ="F" then Do:
Assign ttCustomer.GroupCode = "Fusion"
ttCustomer.CustGrupGroupDesc = "Fusion Customer Group ".
End.
End.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of clederer@...
Sent: Thursday, May 09, 2013 1:18 PM
Subject: [Vantage] Creating a BPM (Epicor 9.05.702)
I'm new to Epicor and had a question about how to create a certain BPM. Ideally
this is what I want, but I'm not sure what conditions to use:
If the "Customer ID" starts with "F" then "Customer Group" would automatically
populate to "Fusion."
Does anyone know how this would be possible or where I can find assistance?
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg Payne
End.
End.
