Creating SSRS from 3 BAQs
I have 3 BAQs I added to an RDD and create the new report. My issue is I don’t see 3 datasets in the report, just 2. Missing “TopLevel”. I checked the datasets to see if the data was hiding in one of those but it’s not, just the data from each BAQ.
Show the relationship details
Relation types are not filled in?
As soon as I pick a Parent, the relation type turns grey and I can’t select one, even if I select the type first.
Maybe you just need to add the dataset to your rdl manually?
I found that if you use BAQ Parameters instead of “Relations” then you will get 3 separate Datasets and you can do the join in the SSRS Select.
DaveO
That’s usually how I do it too, just curious to hear if it can work with the relationships instead.
If you make changes after your created RDL file, you should use the Sync Data Set option as follows:
Or
Rename and rdl, and attempt to create new.
Hi,
Should I put the parameters in all 3 BAQs? I have them in the TopLevel BAQ.
Ms. Melissa: Yes generally all three. It depends on what each baq needs to run and be in Sync with the main BAQ.
DaveO
I am uncertain about the version you are referring to, but in the latest version I tested, the parameter for the top-level BAQ will be sufficient, and you do not need to repeat the same parameter for each BAQ. However, if you have a correct data relation setup.
Interesting thread, never tried to join the datasets from there.
Steps to Create a Report (Example)
Step 1: Define the BAQs
  • OrderHeader: Top-level BAQ with Parameter OrderNum
  • OrderDetails: Second-level BAQ
  • OrderRelease: Third-level BAQ
Step 2: Create the Report Data Definition
Step 3: Establish Data Relationships
Step 4: Add the following criteria to the set Filter:
Step 5: Create the Report Style as shown below
Step 6: Open the RDL file in Report Designer as shown below
Step 7: Added the report to the menu
Step 8: Tested the report and verified that it functions as expected
Step 9: Check the report data in database and it generated only filtered data
Wow, thanks for the write up, I will have to try this out.
This is awesome and has gotten me closer than ever!! I’ve gotten my data down to 2 BAQs, both of which return the information I’m looking for. When I open the SSRS I can see all the fields I need from both BAQs. However, when I print preview the report I don’t get any data. It renders and I can see the labels but not the data.
Do you see the datasets for each of the BAQs in the .rdl?
They are all under 1 dataset but those are the fields from both BAQs.
Ms. Melissa: double check that your tablix is set to use the correct dataset.
Click in the tablix area and then click on the small sqare in the Upper left.
Then check to make sure the Dataset property is set to your KitInOut Dataset.
Thanks. I checked and it is in the tablix parameters. I decided to put all the fields on the report to see if any data was coming through. It looks like the secondary data from the UD10 table is pulling correctly, but not the top level data.
The partlot_partnum and partlot_lotnum are what I am entering as filters for the report.
