Thanks for this. Much appreciated.
Sent: Wednesday, 15 April 2015 9:18 PM
Subject: [Vantage] Re: Credit hold data - 9.05.700C
I know you're placing it on a report, but this is the answer from yesterday for a BAQ:
Order-credit hold is tied to both the Sold To and Bill To customer id's. If either of those are on Credit Hold, the
corresponding Order will be on hold. The OrderHed table has a Credit Override that gets set if you want the specific order released.
1) In your BAQ have OrderHed and Customer. Add Customer a second time to the BAQ (comes in as Customer1).
2) Create a calculated field called OrderCreditHold, with this as the calculation:
"if OrderHed.BTCustNum = Customer1.CustNum and Customer1.CreditHold = True and OrderHed.CreditOverride = True then False else
if OrderHed.BTCustNum = Customer.CustNum and Customer.CreditHold = True and OrderHed.CreditOverride = True then False else
if OrderHed.BTCustNum = Customer1.CustNum and Customer1.CreditHold = True and OrderHed.CreditOverride = False then True else
if OrderHed.BTCustNum = Customer.CustNum and Customer.CreditHold = True and OrderHed.CreditOverride = True then True else False"
Customer is joined to OrderHed on CustNum. Customer1 is joined to OrderHed on BTCustNum
Notice:This e-mail and any attachments are confidential and are only for the use of the person to whom they are addressed. If you are not the intended recipient please advise the sender by return e-mail and delete the message and any attachments. Any use, interference with, disclosure or copying of this message or any attachments is unauthorised and prohibited. The sender does not warrant that the information is free of a virus or any other defect or error, and any views expressed herein, unless specifically indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
