My version (10.1.500.0) of the document shows this on page 167. I think this is the answer:
License Options
You can set up EWA to launch through specific licenses. This topic describes how you set up EWA to launch
through these licenses.
You activate various licenses by adding the ?LicenseType= option at the end of the URL address. Then when
users log into this web site, this license type activates. The EWA interface displays using the selected license.
Note that you must substitute some values in these listed web site addresses.
• [YourServerName] - The name of the server where you installed EWA.
• [YourSiteName] - The name you specified during installation for the Epicor Web Access site.
CRM
The Customer Relationship Management (CRM) license restricts the interface to only display programs related
to the CRM module. To restrict EWA to only display CRM programs, enter the following URL:
• http://[YourServerName]/[YourSiteName]/default.aspx?LicenseType=CRM
MES
The Manufacturing Execution System (MES) menu displays the interface you typically use on the shop floor. To
set up a web site address to display EWA using the MES interface, you enter the following URL:
• http://[YourServerName]/[YourSiteName]/Erp.Menu.MES.MesMenu.aspx
Time and Expense
The Time and Expense license limits the EWA interface to only display programs related to entering time and
expense records. To restrict EWA to only display these Time and Expense programs, enter this URL:
• http://[YourServerName]/[YourSiteName]/default.aspx?LicenseType=TE
Epicor
This is telling me that the “?LicenseType” will define the license utilized. This info contradicts the info given from my CAM.
Ben
