The best ones are always the simplest!!!
Thanks very much.
Sophie
Thanks very much.
Sophie
> -----Original Message-----
> From: Troy Funte [SMTP:tfunte@...]
> Sent: 11 December 2000 17:40
> To: vantage@egroups.com
> Subject: Re: [Vantage] Re: crsystal
> When you click on the details section under Format Section, then the
> "Format with Multiple Columns" shows up at the bottom of the list.
> Troy Funte
> Liberty Electronics
> Â ----- Original Message -----
> Â From: JillSeath@...
> Â To: vantage@egroups.com
> Â Sent: Monday, December 11, 2000 3:31 AM
> Â Subject: [Vantage] Re: crsystal
> Â Ted,
> Â In format Section I only have the following options:
> Â Free-Form Placement
> Â Hide (Drill Down OK)
> Â Suppress (No Drill Down)
> Â Print at bottom of Page
> Â New Page Before
> Â New Page After
> Â Keep Together
> Â Suppress Blank Section
> Â Underlay Following Scetions
> Â I'm using Crystal Version 8 Professional.
> Â Have I gone into the wrong area?
> Â Thanks in advance
> Â Sophie
> Â --- In vantage@egroups.com, "Ted Kitch" <ted@m...> wrote:
> Â > If you go to Format Section, then check the box for Format with
> Â Multiple Columns, you can specify how many columns you want.
> Â >
> Â > Ted Kitch
> Â > ted@m...
> Â >Â Â ----- Original Message -----
> Â >Â Â From: Jill Seath
> Â >Â Â To: 'vantage@egroups.com'
> Â >Â Â Sent: Friday, December 08, 2000 8:17 AM
> Â >Â Â Subject: [Vantage] crsystal
> Â >
> Â >
> Â >Â Â Having created a report using Job Asbl, Oper and Mtl I would
> like
> Â to be
> Â >Â Â able to get the materials to print across the page on one line
> Â instead
> Â >Â Â of downthe page using one line per material.
> Â >Â Â Does anyone know if this is possible?
> Â >Â Â Thanks in advance
> Â >Â Â Sophie
> Â >
> Â >
> Â >
> Â >
> Â >Â Â Â Â Â Â Â Â eGroups Sponsor
> Â >Â Â Â Â Â Â Â
> Â >
>  >  We no longer allow attachments to files. To access/share Report
> Â Files, please go to the following link:Â
> Â <http://www.egroups.com/files/vantage/>
> Â >Â Â (Note:Â If this link does not work for you the first time you
> try
> Â it, go to www.egroups.com, login and be sure to save your password,
>  choose My Groups, choose Vantage, then choose Files. If you save
> the
> Â password, the link above will work the next time you try it.)
> Â >
> Â >
> Â >
> Â > [Non-text portions of this message have been removed]
> Â Â Â Â Â Â
> Â (Note:Â If this link does not work for you the first time you try
> choose My Groups, choose Vantage, then choose Files. If you save the
> eGroups Sponsor
> Click Here!
> <http://rd.yahoo.com/M=102308.1038796.2731130.908943/D=egroupmail/S=17
> 00007183:N/A=466330/?http://www.yahoo.com>
> (Note:Â If this link does not work for you the first time you try it,
> go to www.egroups.com, login and be sure to save your password, choose
