Crystal Developer Design Blank
I have developed a Crystal report for a label and suddenly in design mode the document appears to be blank! I can run my cursor over the page and the fields will show themselves as an outline and the tooltips will display the field value associated with that spot on the page. When I execute the report, after entering the parameters, the label appears on the screen as though it is twice as wide as it should be with a dotted line down the middle of the label. On the left hand side is the label with its parameter values and the right-hand side is blank. It is as though in design mode I am being shown the right-hand side of this label (the blank one).
Â
I hope I have explained this oddity properly. I have seen this only once before and I just recreated the label from scratch. I am using Crystal XI Release 2.
Thanks -Karl
