I can recreate the problem in Crystal v8. Most of the characters print,
except for the Ã, á and ó when they appear at the end of a character string.
Unselecting the Translate strings didn't correct the problem. I just
thought that I would send this so you didn't think that you are alone. I've
also submitted a support request to Seagate.
Ted Kitch
brosseaus@...]
Sent: Friday, August 04, 2000 8:39 AM
To:
vantage@egroups.com
Subject: RE: [Vantage] Crystal forms in Spanish
It's probably the same as for french. In the File - Report Option for a
report, unselect the TRANSLATE DOS STRING and TRANSALTE DOS MEMO.
ecorral@...]
Sent: 3 août, 2000 19:51
To: '
vantage@egroups.com'
Subject: [Vantage] Crystal forms in Spanish
Hi everyone,
Does anybody knows how to make the forms in Crystal to take the
accents for Spanish.
This is only data imported from Vantage, the titles that I
changed directly to the form
are printing correctly. If a vendor in Vantage contains accents
or tilde á or ñ,
is shows fine, Progress reports are correct, the dbf file
created in Vntgwork is fine,
but when it prints to the Crystal form it puts a letter like an
"f" instead of an "Ã", a "T"
instead of an "é", etc. I already contacted Seagate, and Epicor
and so far nothing.
Of course Seagate says is our software application, I am waiting
in Epicor's answer.
Thank you,
Eunice Corral
Dudek & Bock Spring Mfg. Co.
(773) 379-4100
please go to the following link:
http://www.egroups.com/files/vantage/
http://www.egroups.com/files/vantage/>
_____
http://click.egroups.com/1/7750/13/_/411782/_/965396783/>
_____
