Crystal formula translation
The Iff function and Case statement can be found on the help screens in RB
with examples.
Mark
Sent: Wednesday, June 19, 2002 2:55 PM
Subject: Re: [Vantage] Re: Crystal formula translation
On Wed, 19 Jun 2002 08:13:50 -0400, you wrote:
Hello Mark,
Now the formula works perfect,
Thanx al lot !!!.
I'am more used to work with crystal, but i also want to make some
reports in RB, because sometimes the speed is much better as with
Crystal.
Are there some doc's where the syntax of the formula's is explained?
René
>Sorry, my error. I think RB expexts only one statement so try this nested
>iif.
>iif(ShipDtl.Packages>1,CASE(SHIPDTL.PKGCODE,"V01","1","V02","1","V03",
>"3",""),iif(ShipDtl.Packages=1,CASE(SHIPDTL.PKGCODE,"V01","A","V02","B","V0
3
>"C",""),"")
>Mark
>From: Dr.Byte [mailto:drbyte@...]
>Sent: Tuesday, June 18, 2002 5:42 PM
>On Tue, 18 Jun 2002 17:12:18 -0400, you wrote:
>This is the formula i use
>"3",""),"")
>iif(ShipDtl.Packages=1,CASE(SHIPDTL.PKGCODE,"V01","A","V02","B","V03",
>"C",""),"")
>>At 10:43 PM 6/18/2002 +0200, you wrote:
>>>When i just cut and paste the whole formula in RB , and when i verify
>>>the formula i get an "Syntax Error"...????
>>Could be the formula is bad. Can you past it in an email for us?
>>If not, sometimes R.B. is really picky about spaces (or lack of them) in
>>formulas. Try adding them around the operators ( = > < etc) and also
>>around the commas and parens if that doesn't work.
>>-Wayne Cox
>> Twenty Three -- Information Technology Consulting
>> 828-685-2338
>>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
have
>already linked your email address to a yahoo id to enable access. )
>>(1) To access the Files Section of our Yahoo!Group for Report Builder and
>Crystal Reports and other 'goodies', please goto:
>http://groups.yahoo.com/group/vantage/files/.
>>(2) To search through old msg's goto:
>http://groups.yahoo.com/group/vantage/messages
>>(3) To view links to Vendors that provide Vantage services goto:
>http://groups.yahoo.com/group/vantage/links
>>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>--=== Groeten René ===--
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
Does anyone know how to translate the above formula from Crystal
Reports to Rebort Builder syntax..??
if {ShipDtl.Packages} > 1 then
if {SHIPDTL.PKGCODE} = "V01" then "..." else
if {SHIPDTL.PKGCODE} = "V02" then "..." else
if {SHIPDTL.PKGCODE} = "V03" then "..." else
if {ShipDtl.Packages} = 1 then
if {SHIPDTL.PKGCODE} = "V03" then "..." else "";
R.Marijnissen
HOGEFA B.V.
Holland
Try...
iif(shipdtl.packages >= 1 and lookup(shipdtl.pkgcode,"VO1,VO2,VO3") >
0,"...","")
> R.Marijnissen
> HOGEFA B.V.
> Holland
This might also work:
iif(ShipDtl.Packages>=
1,CASE(SHIPDTL.PKGCODE,"V01","....","V02","....","V03","....",""),"")
mark
Sent: Sunday, June 16, 2002 10:56 PM
Subject: [Vantage] Re: Crystal formula translation
Try...
0,"...","")
> R.Marijnissen
> HOGEFA B.V.
> Holland
On Mon, 17 Jun 2002 08:05:06 -0400, you wrote:
Hello mark,
The formula below works perfect, but i also need the second part of
the if statement in the formula with the crystal syntax, this is
because i need to know the amount of Shipdtl.packages is exactly 1
ore more.
The total crystal syntax is one formula.
R. Marijnissen
Hogefa B.V.
Holland
>mark
>From: lonniedrew [mailto:lonniedrew@...]
>Try...
>0,"...","")
>> R.Marijnissen
>> HOGEFA B.V.
>> Holland
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
>(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
>(2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
>(3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
If you want to return a set of values when ShipDtl.Packages >1 and a
different set when ShipDtl.Packages=1 try
iif(ShipDtl.Packages>1,CASE(SHIPDTL.PKGCODE,"V01","....","V02","....","V03",
iif(ShipDtl.Packages=1,CASE(SHIPDTL.PKGCODE,"V01","....","V02","....","V03",
The only problem you might run into in RB is that the case statement is
limited to 10 values I believe.
Mark
Sent: Tuesday, June 18, 2002 1:05 PM
Hello mark,
ore more.
R. Marijnissen
Hogefa B.V.
Holland
>mark
>Try...
>0,"...","")
>> R.Marijnissen
>> HOGEFA B.V.
>> Holland
>Mark
>Hello mark,
>ore more.
>R. Marijnissen
>Hogefa B.V.
>Holland
>>mark
>>Try...
>>0,"...","")
>>> R.Marijnissen
>>> HOGEFA B.V.
>>> Holland
-Wayne Cox
828-685-2338
"3",""),"")
"C",""),"")
>-Wayne Cox
> 828-685-2338
iif.
"3",""),iif(ShipDtl.Packages=1,CASE(SHIPDTL.PKGCODE,"V01","A","V02","B","V03
"C",""),"")
Mark
"3",""),"")
"C",""),"")
>-Wayne Cox
> 828-685-2338
Hello Mark,
Thanx al lot !!!.
Crystal.
René
>iif.
>"C",""),"")
>Mark
>"3",""),"")
>"C",""),"")
>>-Wayne Cox
>> 828-685-2338
