You're not doing any joining on the S/N field, are you? Perhaps write a Formula on the S/N field and use the formula in your report instead of the raw field.Â
Something like:
IF {SERIAL NUMBER} <> "" THEN {SERIAL NUMBER} ELSE "NO S/N"
This way, you'll always have "something" in that field. Feel free to email me directly your XML and RPT and I'll take a looksee.
Sent: Monday, June 23, 2014 10:11 AM
Subject: [Vantage] Crystal grouping question
I have built a BAQ report to print conformance certifications. One of the report results is the serial number. Not all of the shipdtl lines coming down will have a serial number. My problem is this- I can see in Crystal that all the detail lines are coming down properly whether they have a serial number or not. But when I pull the data into the report, the only lines that will print are the ones that have a serial number.
I am grouping my report by pack number and pack line. Any ideas - is my grouping wrong?
Thanks-
Pat
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-405697330 code
font-family:“Courier New”;}
#ygrps-yiv-405697330 pre
margin:0in;
margin-bottom:.0001pt;
font-size:10.0pt;
#ygrps-yiv-405697330 tt
#ygrps-yiv-405697330 span.ygrps-yiv-405697330cat
#ygrps-yiv-405697330 span.ygrps-yiv-405697330ct
#ygrps-yiv-405697330 span.ygrps-yiv-405697330HTMLPreformattedChar
font-family:“Consolas”, “serif”;}
#ygrps-yiv-405697330 p.ygrps-yiv-405697330attach, #ygrps-yiv-405697330 li.ygrps-yiv-405697330attach, #ygrps-yiv-405697330 div.ygrps-yiv-405697330attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-405697330 p.ygrps-yiv-405697330bold, #ygrps-yiv-405697330 li.ygrps-yiv-405697330bold, #ygrps-yiv-405697330 div.ygrps-yiv-405697330bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-405697330 p.ygrps-yiv-405697330green, #ygrps-yiv-405697330 li.ygrps-yiv-405697330green, #ygrps-yiv-405697330 div.ygrps-yiv-405697330green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-405697330 p.ygrps-yiv-405697330replbq, #ygrps-yiv-405697330 li.ygrps-yiv-405697330replbq, #ygrps-yiv-405697330 div.ygrps-yiv-405697330replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-405697330 p.ygrps-yiv-405697330ad, #ygrps-yiv-405697330 li.ygrps-yiv-405697330ad, #ygrps-yiv-405697330 div.ygrps-yiv-405697330ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-405697330 p.ygrps-yiv-405697330underline, #ygrps-yiv-405697330 li.ygrps-yiv-405697330underline, #ygrps-yiv-405697330 div.ygrps-yiv-405697330underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-405697330 span.ygrps-yiv-405697330yshortcuts
#ygrps-yiv-405697330 p.ygrps-yiv-405697330ad1, #ygrps-yiv-405697330 li.ygrps-yiv-405697330ad1, #ygrps-yiv-405697330 div.ygrps-yiv-405697330ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-405697330 p.ygrps-yiv-405697330ad2, #ygrps-yiv-405697330 li.ygrps-yiv-405697330ad2, #ygrps-yiv-405697330 div.ygrps-yiv-405697330ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-405697330 p.ygrps-yiv-405697330underline1, #ygrps-yiv-405697330 li.ygrps-yiv-405697330underline1, #ygrps-yiv-405697330 div.ygrps-yiv-405697330underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
text-decoration:underline;}
#ygrps-yiv-405697330 span.ygrps-yiv-405697330yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-405697330 span.ygrps-yiv-405697330yshortcuts2
font-weight:normal;}
#ygrps-yiv-405697330 span.ygrps-yiv-405697330EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-405697330 .ygrps-yiv-405697330MsoChpDefault
font-size:10.0pt;}
_filtered #ygrps-yiv-405697330 {
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-405697330 div.ygrps-yiv-405697330WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-405697330 ol
{margin-bottom:0in;}
#ygrps-yiv-405697330 ul
Bring up your crystal form drop down menu Database/Database Expert then the LINKS tab double click on the link between ShipDtl and Serial Number Table and make sure it’s an Outer Join.
Patrick Winter
Sent: Monday, June 23, 2014 09:11
Thanks-
Pat
