Crystal report collate
From what I have read on the internet the problem resides in crystal reports. CR says that the problem was fixed in CR 2008. can vista 8.03.409c use crystal 2008?? I would upgrade from CR XI
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> This is a very much known "bug" and PITA in my company after upgrading all
> workstations to Windows 7 Pro x64.
> It's not Vantage/Vista/Epicor. It's the Crystal Runtime in a 64-bit
> environment of Win 7. (seems to work fine on 32-bit Win7).
> So your only work around is PREVIEW your Crystal Report instead of just
> printing it from Vista. Then Export to PDF. Then, open the PDF and it will
> print and collate just fine.
> I've tried numerous runtimes, hacks, reg edits and hammers. None worked.
> Googling it shows we're not alone: http://bit.ly/156RJ0v
> Good luck. Post if you resolve... :-)
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Gary Wojtowicz
> Sent: Tuesday, August 20, 2013 4:12 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Crystal report collate
> Running Vista 8.03.409C on windows 7 64 bit
> When printing out multiple copies of a crystal report, it will not collate
> even though the checkbox is checked.
> Has there been a fix for printing out crystal reports that will collate
> Gary Wojtowicz
> AJR Industries, Inc.
When printing out multiple copies of a crystal report, it will not collate even though the checkbox is checked.
Gary Wojtowicz
Gary Wojtowicz
Gary Wojtowicz
