Crystal report only showing quotes with parts in part master
I wouldn't be surprised if it was...in Crystal with that field, do a
left out join to the part table - part number....see if that works!
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of emverbeke
Sent: Thursday, June 18, 2009 1:01 PM
Subject: [Vantage] Re: crystal report only showing quotes with parts in
part master
Yea this is the weird thing. If I do a BAQ all the quotes come up no
matter if the part is in the part master or not. However in crystal it
won't show the quotes with manually entered part numbers it only shows
the quotes with a part number in the part master. I don't even have the
a part number field in the report but the only difference between the
quotes showing up and not showing up is whether or not they are in the
part master file. I'm new to crystal reports and I'm not sure if this
makes a difference or not but in the Database expert there is a black
arrow next to the QuoteDtl.PartNum field but it isn't linked to
anything. I don't know if that is the culprit.
"Manasa Reddy" <manasa@...> wrote:
> boredom at work has made me lazy...sorry...
> The quote module has tables that hold part numbers that are NOT part
of
> the part master table....check out those tables for the info you are
> looking for.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
Behalf
> Of Manasa Reddy
> Sent: Thursday, June 18, 2009 10:27 AM
> Subject: RE: [Vantage] crystal report only showing quotes with parts
in
> part master
> Quote module have their own quote tables...check out quote head and
> quote dtl tables and there is a quoteCoPart...not sure if this would
> hold the info in it but check it out anyway.
> M. Manasa Reddy
> manasa@... <mailto:manasa%40weldcoa.com>
> P: 630-806-2000
> F: 630-806-2001
> Behalf
> Of emverbeke
> Sent: Thursday, June 18, 2009 10:10 AM
> Subject: [Vantage] crystal report only showing quotes with parts in
part
> master
> I've created a sales funnel report in Crystal reports and everything
was
> working fine until we started entering quotes with parts that are in
our
> part master. In my report I'm not even pulling the part number field
but
> the report isn't showing any quotes that have a typed in part number
> (not in the part master). Any ideas how to get Crystal to show it?
I've created a sales funnel report in Crystal reports and everything was working fine until we started entering quotes with parts that are in our part master. In my report I'm not even pulling the part number field but the report isn't showing any quotes that have a typed in part number (not in the part master). Any ideas how to get Crystal to show it?
If I understand correctly, you need to connect to the part master table with
an outer join. If this is from a BAQ you can do that in the phrase builder
in the relationships section.
If you have done this report with ODBC you can double-click the line between
tables in the Database Expert links section and select it there.
This will display all of the quote parts and only the part data from the
part master if it exists.
Ross
emverbeke
Subject: [Vantage] crystal report only showing quotes with parts in part
master
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of emverbeke
master
The quote module has tables that hold part numbers that are NOT part of
looking for.
M. Manasa Reddy
manasa@...
P: 630-806-2000
F: 630-806-2001
Of Manasa Reddy
Subject: RE: [Vantage] crystal report only showing quotes with parts in
part master
M. Manasa Reddy
P: 630-806-2000
F: 630-806-2001
Behalf
Of emverbeke
master
Yea this is the weird thing. If I do a BAQ all the quotes come up no matter if the part is in the part master or not. However in crystal it won't show the quotes with manually entered part numbers it only shows the quotes with a part number in the part master. I don't even have the a part number field in the report but the only difference between the quotes showing up and not showing up is whether or not they are in the part master file. I'm new to crystal reports and I'm not sure if this makes a difference or not but in the Database expert there is a black arrow next to the QuoteDtl.PartNum field but it isn't linked to anything. I don't know if that is the culprit.
> looking for.
> M. Manasa Reddy
> manasa@...
> P: 630-806-2000
> F: 630-806-2001
> Of Manasa Reddy
> part master
> M. Manasa Reddy
> P: 630-806-2000
> F: 630-806-2001
> Behalf
> Of emverbeke
> master
