Sue
I'm hearing 2 issues here.
1) Modifing standard forms like Job Travelers, PO and Invoices. You
don't need ODBC and Merant drivers to do that. You just point Report
Style Maintenance at a modified report and you're done. The data for
the reports is generated at print or print preveiw time in
C:\vntgwork as DBase2 dbf files. A Crystal Reports Print Engine
(CRPE) is called by Vantage with parameters pointing at the rpt and
dbf files.
2) Using Crystal reports as the reporting tool attached to the
Vantage database. The Merant drivers have been included with the
vantage installation since 5.0 or 5.1. Search the epicor site for
setup instuctions. When it is setup Crystal connects through ODBC.
HTH
Russ Dover
2) Using Crystal Reports a
To: <vantage@yahoogroups.com>
Subject: RE: [Vantage] Crystal Report PROBLEMS when trying to modify forms
dbf files.
HTH
Russ Dover
> Epicor responded and the problem was resolved. How? By copying the
> crystal .dll files from WINNT\Crystal to WINNT\System32. But I still
> need to know where I can find the MERANT driver (see below):
> Thank you,
> Sue
> -----Original Message-----
> From: Susan Iverson
> Sent: Friday, June 11, 2004 8:03 AM
> To: vantage@yahoogroups.com
> forms
> Thanks to those who have responded so fast. I'll work on this today
> using the info you've given me. One more question: How do I get hold
> of
> the MERANT 3.60 32-BIT PROGRESS SQL92 V9.1D driver? I take it this
> is a
> necessity to have in the System DSN on the workstation that will be
> doing any Crystal Reporting in Vantage.
> Thank you,
> Sue
> From: Frank Zeigafuse [mailto:fzeigafuse@...]
> Sent: Friday, June 11, 2004 5:48 AM
> forms
> it smells like a odbc issue.
> One thing to note is you have to check your vtg file. It should like
> something like below, silly epicor when you install 6.x or one of them
> it
> changes your vtg file and adds a : I think or some character to the
> bottom
> where odbc is listed. I think it treats it as a remark. WE have had
> very
> good luck with changing forms. Some important steps.
> 1. create a separate folder for modified forms
> 2. save this wip process form to this location, you will work from
> this
> modified form so you always have the original
> 3. go to vantage and print preview whatever form you want, this will
> create
> the dbf file
> 4. make sure your set the database location. c:\[depends on version
> of
> vantage]
> 5. hit f5 to refresh form to use data from #4, now you should see
> what
> was
> on the print preview
> 6. have fun.
> [MFG Startup]
> Executable=M:\prgs91d\bin\prowin32.exe
> Database=M:\mfgsys61\db\MFGSYS
> IniFile=M:\mfgsys61\mfgsys.ini
> ParameterFile=M:\mfgsys61\db\mfgsys.pf
> ConnectOptions=-N TCP -H ibm6 -S 6100 -ld MFGSYS
> TempDirectory=C:\vntgwrk
> StartupProcedure=mainmenu.w
> OtherParameters=-rand 2 -q -basekey ini
> mfgsys=VN
> mfglanguage=enu
> mfgtranslator=yes
> unicode=true
> MFGODBCpasswd=admin
> MFGODBCUser=admin
> MFGODBCDbse=mfgsys
> MFGODBCServer=Progress Remote OID
> Frank Zeigafuse
> Innovative Office Products
> General Manager
> Direct Phone: 610-559-6369
> Email: fzeigafuse@...
> From: Susan Iverson [mailto:siverson@...]
> Sent: Thursday, June 10, 2004 7:25 PM
> To: Vantage User Group
> Subject: [Vantage] Crystal Report PROBLEMS when trying to modify forms
> Here I was so excited to be able to modify forms using Crystal and I
> get
> met with problem after problem after I try to do it for the first
> time.
> On one workstation, after I've opened the form, go to set location and
> then find database, after I select it we get a MS ACCESS PASSWORD
> popup
> that doesn't accept any password whatsoever.
> On another workstation, I can't even open the form - I get a FAILED TO
> OPEN DOCUMENT/INVALID REPORT VERSION.
> On yet another workstation, again I can't even open the form - I get a
> "TLV" error.
> We are on Vantage 6.1.5 using the latest update of Crystal 8.5 (I
> know 9
> and 10 are out there) but 8.5 is supposed to work. Has anyone else
> experienced this problem? If so, were you able to fix it?
> If anyone out there is using the same version of Vantage as I am and
> you
> are able to modify Vantage Forms using Crystal, what version of
> Crystal
> are you using?
> I called Epicor tech support and the guy said that I'm the second one
> this week to call with this problem. He's researching it.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> <http://groups.yahoo.com/group/vantage/files/>
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/SIG=129kalemu/M=298184.5022502.6152625.3001176/D=
> gr
> oups
> /S=1705007183:HM/EXP=1086996354/A=2164331/R=0/SIG=11eaelai9/*http://ww
> w.
> netf
> lix.com/Default?mqso=60183351> click here
> <http://us.adserver.yahoo.com/l?M=298184.5022502.6152625.3001176/D=gro
> up
> s/S=
> :HM/A=2164331/rand=575557762>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service
> <http://docs.yahoo.com/info/terms/> .
> <www.LCDarms.com> -- Ergonomic mounting solutions for monitors and
> keyboards
> This e-mail is from Innovative Office Products, Inc. but expresses the
> views of the sender and not necessarily the views of the company. The
> email and any files transmitted with it are confidential to the
> intended
> recipient at the e-mail address to which it has been addressed. It may
> not be disclosed or used by any other than that addressee, nor may it
> be
> copied in any way. If received in error, please delete and notify the
> sender via e-mail or sales@... quoting the name of the sender.
> Messages sent via this medium may be subject to delays, non-delivery
> and
> unauthorized alteration. This e-mail has been prepared using
> information
> believed by the author to be reliable and accurate. Unless expressly
> stated otherwise, this e-mail does not form part of a legally binding
> contract or agreement between recipient and Innovative Office
> Products,
> Inc.
> Warning: Although Innovative Office Products, Inc. has taken
> reasonable
> precautions to ensure no viruses are present in this email, we cannot
> accept responsibility for any loss or damage arising from the use of
> this email or attachments. It is, therefore, your responsibility to
> scan
> attachments (if any).
> have already linked your email address to a yahoo id to enable
> access. )
> and Crystal Reports and other 'goodies', please goto:
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/SIG=1299vp562/M=298184.5022502.6152625.3001176/D=
> gr
> oups/S=1705007183:HM/EXP=1087044510/A=2164339/R=0/SIG=11e2d64in/*http:
> /w
> ww.netflix.com/Default?mqso=60183348>
> up
> s/S=:HM/A=2164339/rand=950488247>
> _____
> Yahoo! Groups Links
> Service <http://docs.yahoo.com/info/terms/> .
> access. )
> ADVERTISEMENT
> click here
> <http://rd.yahoo.com/SIG=129tav1sf/M=298184.5022502.6152625.3001176/D=
> gr
> oups/S=1705007183:HM/EXP=1087052603/A=2164330/R=0/SIG=11eamf8g4/*http:
> /w
> ww.netflix.com/Default?mqso=60183350>
> up
> s/S=:HM/A=2164330/rand=702898349>
> _____
> Yahoo! Groups Links
> must have already linked your email address to a yahoo id to enable
> access. )
