I have done that exact thing.
we have 2 logo's sitting on the server where everyone can get to them with \\servername\jpg\
Create a parameter in crystal to allow them to select the logo wanted when they print.
then I created a path formula that created the path to the correct logo using the parameter they entered.
Then add the logo to your report - just select the the one used most.
then right click on the logo in Crystal and select format graphic
click on the picture tab and X-2 button beside Graphic
select the path formula.
Â
That's it - when they run the parameter asks them which logo to use, the path formula selects the correct path using the selection then the image is linked to the image using the path.
Â
If you have any trouble then I can create you a quick example.
Â
Â
Sent: Wednesday, June 8, 2011 9:43 AM
Subject: [Vantage] Crystal Report Question - Reference an image file for company logo
Â
Is it possible to have CR reference a file for an image?
Nothing fancy, the image refernce would be static (not based on database info or report parameters).
The company I consult for wants to be able to change the Logo on reports (like the Quote, Order an Packer printouts) fairly regulary.
And instead of having to edit the report in CR Developer every time the artwork changes, I'd like to reference an image file, that they could just replace when a new one is needed.
Calvin
Â
Â
Â
Â
Â
Calvin
