Crystal Reports 2008 & Epicor 9.05.606
What you will need to do is setup a new report style that uses the new RDD, and then run the report using this new style/rdd. Then go into the directory that has the Epicor data directory where there should be a directory for the user account you used to run the report. Go into that directory. If you sort the directory by date modified you should be able to find the file just created, it will have a name prefix in line with the report you just ran. Take the xml file and put it somewhere so it doesn't disappear if your location does file clean up of this directory. I like to put it on a local drive so that the file isn't on a network drive while I am working with it.
Now when you open your crystal report in Crystal Reports and you get prompted for the file location, click the browse button and find the file from above. You may have to do a verify database. You should see your new fields. If you make changes to the RDD you need to re-run the report, get the XML, and change file name in the data-source location. I found that Crystal caches things (at least in some versions) so you may need to exit crystal and come back in to get it to pickup the new file.
Once you have made the changes you want on the report save a copy to the server\reports\customreports directory. Then go to the report style you created above and change the form location/name to the one you just put in the custom reports directory.
Jim Kinneman
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, "swenson.justin" <swenson.justin@...> wrote:
> I'm trying to edit a report made for us a while ago. It's my first time using both Crystal Reports and creating a report within Epicor. I'm getting stuck with the process.
> I've figured out the basics of what the Report Data Definition and Report Style screens do in Epicor and figuring out how to edit a report within Crystal is simple enough. My problem is figuring out how the connections between the two work.
> I can select the specific report I want within the CustomReports folder on the Epicor server, but why does it then try to make me pick a specific XML file that's been saved to a person's name (ex. John Doe) which is stored in a completely seperate location on the C drive. It does this when I try to update the report to show the new fields I've included from Epicor.
> All I'm trying to do is include a few new user defined fields I recently set-up. Getting them to appear in Crystal has been a chore.
> Thanks,
> Justin
Justin
You need to link them to an XML file in a users report folder to link the DATA to the report - so that Crystal knows the tables and/or fields have changed. Once you have made the link (as long as you make sure to uncheck "save data with report" - under file) then the report uses each XML file the user creates after you save the report. You need to see if your fields show up in the database fields and if not, try the Database menu, verify database...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of swenson.justin
Sent: Friday, April 13, 2012 1:47 PM
Subject: [Vantage] Crystal Reports 2008 & Epicor 9.05.606
Justin
