Jim,
There are 3 settings you have to change to use memo or other fields.
1. In the alignment properties, check 'word wrap'
In the Format properties,
2. Change the 'character format' to x(300)
3. Set the field width to whatever is appropriate for your report.
Hope this helps.
John Himebaugh
MIS
InterOcean Systems, Inc.
3540 Aero Court
San Diego, CA 92123
858.565.8400
johnh@...
Sent: Thursday, October 12, 2000 12:39 PM
To: vantage@egroups.com
Subject: [Vantage] Crystal Reports and a Memo field
When I look up a comment or memo field, Invoice Detail.Invoice Comment for
example Crystal only recognizes the item as 8 characters. Any ideas on how
to report on the memo fields with Crystal?
Jim Carnes
Hope this helps.
John Himebaugh
MIS
3540 Aero Court
San Diego, CA 92123
858.565.8400
johnh@...
Jim Carnes
