Thanks, Kurt, but those check boxes were already unchecked, and there are no stored procedures. Any other ideas?
THOM ROSE
Controller
Electric Mirror
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of kurt_hilborn
Sent: Friday, March 22, 2013 12:10 PM
Subject: [Vantage] Re: Crystal Reports Error
I had the same issue with a few reports. I found that Crystal was set to Save Data With Report under File > Report Options and File > Options. Make sure the boxes are not checked.
If that doesn't work check any stored procedures to make sure they are running correctly.
THOM ROSE
Controller
Electric Mirror
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Thomas Rose <t.rose@...> wrote:
> Ver 8.03.403
> I have a Crystal/BAQ report that combines data from the BAQ with data from an ODBC query of the database (Thank you, idiot database analyst who combined all the sales reps on an order into one field). The report runs just fine when I run it, but when another user tries to run it, it errors out with "Failed to open the connection". I have the same ODBC connection setup on the user's PC as mine, so I don't understand why it fails there, but not on mine. Any thoughts?
