Crystal Reports Problem
Thanks, Terry, I'll give that a try. I cheated in the meantime and created a
formula for the date using the ToText function and dropped that into the header.
That also works.
Regards,
-Karl
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Sat, July 3, 2010 1:51:38 PM
Subject: Re: [Vantage] Crystal Reports Problem
Â
When you create a group header on a date field there is and option to group by
day, week, month, year... I believe it defaults to week which would cause the
results you ate seeing.
Right click the group header on the design tab and select change group to set
the group by value.
Terry S Ellis
Consultant
716-983-8827
Sent from my mobile device
On Jul 3, 2010, at 4:20 PM, Karl Dash <dashkarl@...> wrote:
> I am bringing a .csv file into Crystal report. One column is a date field
> formatted in Excel as M/DD/YY. I have successfully brought the file into
>Crystal
> but when I use the date field as a group header, it converts it to the Sunday
> closest to the actual date. i.e. 1/1/07 becomes 12/31/06 and 2/2/07 becomes
> 1/28/07. If I put the date into the detail line it displays correctly. I have
> never seen anything so Bizarre. Is this an undocumented feature of Crystal XI
> (ver 11.5.3.417)?
> Any help?
> Thanks,
> -Karl
I recently implemented ODBC so I can use Crystal Reports with my Vantage
database. Made a simple one table report and everything worked fine. I
then started to create a report with some joins. The particular report I
am creating contains the Customer table and the InvcDtl Table with an
Outer Join on the Company and CustNum fields. When I run the report I
get the following error:
ODBC Error:[DataDirect-Technologies][ODBC Progress Drivers]The keywords
LEFT OUTER JOIN were not found in an outer join escape sequence.
Anyone know tell me what that means and how to work around it?
Thank for your help
Todd Hofert
IT Director
Spartan Graphics, Inc.
I believe there is an ODBC fix for that. If you call Epicor, they can send it to you along with the instructions.
Jasper
Sent: Thursday, January 22, 2004 8:16 AM
Subject: [Vantage] Crystal Reports Problem
Thank for your help
Todd Hofert
IT Director
Yahoo! Groups Links
To visit your group on the web, go to:
To unsubscribe from this group, send an email to:
Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
Sent: Thursday, January 22, 2004 5:16 AM
Thank for your help
Todd Hofert
IT Director
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cvobnh3/M=267637.4116730.5333196.1261774/D=egroup
web/S=1705007183:HM/EXP=1074863738/A=1945637/R=0/*http://www.netflix.com/Def
ault?mqso=60178397&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmai
l/S=:HM/A=1945637/rand=922151250>
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
Todd, you might also open the Crystal Reports "visual linking expert" in the
database pull down menu, highlight one of the joins between tables, and
using the "link options" button change the link from "equal" to "left
outer". If memory serves me correctly, changing one link between tables
changes them all.
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Sent: Thursday, January 22, 2004 7:16 AM
Thank for your help
Todd Hofert
IT Director
Yahoo! Groups Links
Question for anyone who has worked with these devices before. I'm trying to
fix a problem for another company whose IT guy quit, no notice. The owner
has a SOHO that connects to the FB2 as a VPN. The thing that is strange is
that Remotely when he starts WinXP he is being autheticated via the PDC at
the office with a roaming profile. Forgetting the bandwidth involved I've
never come across this situation. Has anyone dealth with a similar
situation that may be able to help me off list.
Thanks for the info/advice.
I now return you to your normally scheuled Vantage issues.
Jim Carnes
Information Systems Administrator
jcarnes@...
Kenlee Precision Corporation
1700 Morrell Park Ave
Baltimore, MD 21230
I contacted support per a previous users post (Jasper Recto) and they do
have a fix. I implemented it and I am up and running
Thank You.
Sent: Thursday, January 22, 2004 10:08 AM
Subject: RE: [Vantage] Crystal Reports Problem
the database pull down menu, highlight one of the joins between tables,
and using the "link options" button change the link from "equal" to
"left outer". If memory serves me correctly, changing one link between
tables changes them all.
Norm Watkins
Engineering Mgr.
ELECPAC
847-639-2307
Thank for your help
Todd Hofert
IT Director
Yahoo! Groups Links
Yahoo! Groups Links
Todd,
While you wait for the patch you can also click on the database menu at the
top, and click on Visual Linking Expert. It will show the tables in your
report with the joins between them. Click on one of the links, and then
click on the link options button and change it to "left outer join".
Depending on how your report is set up you may need to do this for more than
on (maybe even all) of the links you have. I don't have the patch to fix
it, but doing this lets all the reports I have run fine.
Liz Hahn
Buyer
Guntert & Zimmerman
Thank for your help
Todd Hofert
IT Director
I have the patch handy - I can email you off list if you would like. I
simple registry file that you double-click and import.
Let me know,
Brandon R Murch
Director of Information Technology
WindStone Medical Inc.
(406)259.6387
bmurch@...
Sent: Thursday, January 22, 2004 8:50 AM
Todd,
the
your
than
fix
Liz Hahn
Buyer
Guntert & Zimmerman
Thank for your help
Todd Hofert
IT Director
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Service.
Thanks to all that have responded. I have the problem corrected. The
registry entry recommended by several is the approach I took and it
works. Thanks again.
Todd Hofert
Sent: Thursday, January 22, 2004 10:57 AM
Let me know,
Brandon R Murch
(406)259.6387
bmurch@...
Todd,
the top, and click on Visual Linking Expert. It will show the tables in
your report with the joins between them. Click on one of the links, and
then click on the link options button and change it to "left outer
join".
than
fix
Liz Hahn
Buyer
Guntert & Zimmerman
Thank for your help
Todd Hofert
IT Director
_____
Yahoo! Groups Links
Yahoo! Groups Links
Hi Brandon (or anyone else who can help),
It's been four years since this was posted, but I'm having the same
problem mentioned below. We have some old reports in Crystal 8.5 on
Vantage 6.1 and are having problems with them. We get this
error "The keywords LEFT OUTER JOIN were not found in the outer join
escape sequence."
We have the Merant 3.6 driver and would like to have the Merant 3.7
driver, but cannot find it. So it looks like I need this patch
mentioned below. Do you have it or does anyone know of a better
approach.
like. I
> Let me know,
> Brandon R Murch
> (406)259.6387
> bmurch@...
> From: ehahn@... [mailto:ehahn@...]
> Todd,
menu at
> the
> your
then
more
> than
to
> fix
> Liz Hahn
> Buyer
> Guntert & Zimmerman
> From: Todd Hofert [mailto:todd@...]
Vantage
fine. I
report I
an
I
keywords
> Thank for your help
> Todd Hofert
> IT Director
must
access. )
Builder
> _____
> Yahoo! Groups Links
of
I also am now experiencing the same error. I am just starting to use Crystal 8.5 with vantage 6.1x.... Do I need an update of ODBC driver? Can anyone supply it?
> escape sequence."
> approach.
> like. I
> > Let me know,
> > Brandon R Murch
> > (406)259.6387
> > bmurch@
> > From: ehahn@ [mailto:ehahn@]
> > Todd,
> menu at
> > the
> > your
> then
> more
> > than
> to
> > fix
> > Liz Hahn
> > Buyer
> > Guntert & Zimmerman
> > From: Todd Hofert [mailto:todd@]
> Vantage
> fine. I
> report I
> an
> I
> keywords
> > Thank for your help
> > Todd Hofert
> > IT Director
> must
> access. )
> Builder
> > _____
> > Yahoo! Groups Links
> of
formatted in Excel as M/DD/YY. I have successfully brought the file into Crystal
(ver 11.5.3.417)?
Any help?
-Karl
When you create a group header on a date field there is and option to group by day, week, month, year... I believe it defaults to week which would cause the results you ate seeing.
Right click the group header on the design tab and select change group to set the group by value.
Terry S Ellis
Consultant
716-983-8827
> (ver 11.5.3.417)?
> Any help?
> Thanks,
> -Karl
