We currently using Crystal version 6 without a problem. However, we are
going to upgrade to version 8. Both versions are "Professional". I believe
Epicor has indicated they are using version 7 in Vantage 4.0
Warren Eddy
National Tube Form LLC
Sent: Friday, September 15, 2000 11:46 AM
To: vantage@egroups.com
Subject: [Vantage] Crystal Reports Version?
A quick question. What version of Crystal Reports is needed for Vantage 4.0.
Can you use the standard version or do you need the professional. Thanks
Dave Schnorr
Warren Eddy
Dave Schnorr
