Crystal Reports XI R2 Runtime on Windows Server 2008 R2 x64
We are using the standard .NET runtime for the clients. Any ideas for
this?
Christopher W. Marsch
IT/Database Administrator
Mechanical Dynamics & Analysis, Ltd.
19E British American Blvd.
Latham, NY 12110
(518) 399-3616 x272
Cell: (518) 795-0200
Of Jen
Sent: Tuesday, June 21, 2011 5:18 PM
Subject: [Vantage] Re: Crystal Reports XI R2 Runtime on Windows Server
2008 R2 x64
Make sure you are using the odbcad32 file from the Windows-->SysWOW64
folder.
Also, in the DSN setup use the server IP address, not the server name.
We are using VMWare (R2 64 bit server) and RDS for the clients (R2 64
bit)
"Marsch, Chris" <cmarsch@...> wrote:
> We just setup a new XenApp 6 environment on Windows Server 2008 R2 x64
> and Vantage runs nicely, however, the cryatal reports all fail and I
> have found that the Crystal Reports Runtime for XI R2 does not work
due
> to the 64 bit environment. Has anyone run into this as well and found
a
> workaround for this. We would like to try and move from our current
> Citrix 4.5 to XenApp 6 in the next month or 2. Please any help would
be
> appreciated. Thanks.
> Latham, NY 12110
> (518) 399-3616 x272
have found that the Crystal Reports Runtime for XI R2 does not work due
to the 64 bit environment. Has anyone run into this as well and found a
Citrix 4.5 to XenApp 6 in the next month or 2. Please any help would be
Latham, NY 12110
(518) 399-3616 x272
Make sure you are using the odbcad32 file from the Windows-->SysWOW64 folder.
We are using VMWare (R2 64 bit server) and RDS for the clients (R2 64 bit)
> Latham, NY 12110
> (518) 399-3616 x272
