Try going through everything in this document. No problem has to do with
permissions.
http://support.crystaldecisions.com/communityCS/TechnicalPapers/ce8_looping_
logon.pdf
Ted Kitch
ted@...
Sent: Monday, June 10, 2002 1:17 PM
Subject: RE: [Vantage] Crystal Web Component & looping logins
This worked for me from within Access, Excel, and the Crystal Developer
component. Anytime anyone accesses (no pun) a web report however, they have
to logon-including if I run a report from the web server on the web server
itself. (Sigh) I was just hoping...
Sent: Monday, June 10, 2002 9:38 AM
Subject: Re: [Vantage] Crystal Web Component & looping logins
I wish SQL-92 would give you the option of a blank username and password.
I think this would solve the error 990 on Vantage/ODBC reports. I use
Merant 3.5 drivers for that very reason, and it allows blank login so that
you don't have to type them in everytime.
Having said that, there is a workaround given by Epicor to (in certain
situations, of which ODBC in Crystal is NOT one of them if I recall) to
default the login for you in applications like Access). Maybe it will work
for ODBC now, I don't know.
*****************From Tim Ligas at Epicor**************
SQL-92 -- How to get it to not prompt for a password
Summary: ODBC - SQL92 How to save a password in a "File" DSN
Book: Support Solutions
Page: 1732MPS
How to save a password in a File ODBC Data Source that uses MERANT ODBC
driver (SQL-89 or SQL-92).
XA500
XA510
EXPLANATION:
Some customers ask how can they save the user id and password in the
ODBC Data Source in order to connect to the Progress Database from
another application through ODBC (using the MERANT driver) without any
user input.
SOLUTION:
This kb is valid for SQL-89 and SQL-92, it has been tested with ODBC
MERANT driver 3-60 SQL-89 and SQL-92.
You will have to create a File DSN (instead of a System DSN or User
DSN) through the ODBC Data Source Administartor.
Once you have created it and tested the connection you will modify the
file
just created. By default this file is kept in the directory: C:\Program
Files\Common Files\ODBC\Data Sources. Using Notepad or Wordpad edit and
add
(or modify) the following lines:
UID=<userID>
PWD=<password> <-- Must be in lower case
The UID will already be present as 'sysprogress'. Simply open a new line
just beneith it and add PWD=sysprogress
*** NOTE: Once you have done this, you can't modify or save the File DSN
again on this workstation through the ODBC DS Administrator because it
will
overwrite the file that you have modified and you will need to add one or
both of the lines again.
Afterwards if you, for example, use Excel to get the external data from a
Progress Database you will see that it doesn't ask for any user ID or
password.
Example of a "SQL-92" File DSN after the modifications:
[ODBC]
Driver=MERANT 3.60 32-BIT Progress SQL92 v9.1A
UID=sysprogress
PWD=sysprogress
HOST=ntserver1
PORT=2550
DB=vantage
permissions.
logon.pdf
Ted Kitch
ted@...
Page: 1732MPS
XA500
XA510
EXPLANATION:
user input.
SOLUTION:
file
add
UID=<userID>
will
password.
[ODBC]
UID=sysprogress
PWD=sysprogress
HOST=ntserver1
PORT=2550
DB=vantage
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Monday, June 10, 2002 9:59 AM
Good morning and thanks for the help in geting my web component up and
running. Next question. How can I get the web viewer to match format of
the
native report I see on my development machine. We use I.E 5.0 I think
the
default viewer is the Active X viewer. Also is there a way to provide
default values for the logon box for ODBC reports?
Dan Shallbetter
Sent: Monday, June 10, 2002 8:43 AM
I'm not using the dos command since we went to 5.1, but here's the
content
of the batch file I used in 4.0:
-------------Begin Batch File---------------------------
cls
cd "c:\Program Files\Seagate Software\WCS\"
pageserver.exe -cache -deletecache -console
-------------End Batch File-----------------------------
I put a shortcut in my startup folder to this, set to run minimized.
This was run on a W2k machine, so if you're running on NT, you might
have to
change the "Program Files\Seagate Software\" to "Progra~1\Seagat~1\"
without the quotes.
Hope this helps,
Alan
Sent: Friday, June 07, 2002 9:43 PM
Dan,
You are on the right track. Try using a REAL Admin user for the
Service, rather than the CRUSER that crystal recommends. That worked
for
me.
As an alternative (workaround)...There is a DOS COMMAND you can use (I
think you have to turn the services off) that allows Crystal to run in
your
task bar. It was in some threads here over a year ago. Does anyone
still
have/use Crystal Web their task bar????
Troy Funte
Liberty Electronics
Sent: Friday, June 07, 2002 2:45 PM
Adam
Sopped the service cahnge the user to admin restatred the service
same
results. I can see sample reports usung I.E is the ODBC reports that
are
the
problem.
Dan
Sent: Friday, June 07, 2002 1:20 PM
I believe I did the same thing when I set up my web component server
(creating the Crwebuser and such) and ran into the same problem. It
has
been a while, but I think that switching the user the service was
running
under to Administrator did the trick. Crwebuser may need to have
Log On
Locally rights? Regardless, try switching it to Administrator and
see
if it
works.
AE
Sent: Friday, June 07, 2002 2:13 PM
Adam the Crystal install doc had me create a user Crwebuser and make
him
a
member of the the admin group. This is the user they said to use for
the
web
component service. Is this incorrect?
Dan
Sent: Friday, June 07, 2002 1:01 PM
Dan,
Make sure the web component server is running as user
'Administrator'
under
NT Services.
AE
Sent: Friday, June 07, 2002 2:02 PM
Subject: [Vantage] Crystal Web Component & looping logins
Today's fun and games is setting up the web component in Crystal
8.0. I
am
getting a looping login when I try refreshing a O.D.B.C database
report.
I
think I have followed all the steps listed in the Crystal K.B.
c2009197
I
am a little confused by the step pertaining to NTFS file
permissions. We
are
running S.B.S 4.5 loaded on a NTFS partition. Has anybody already
discovered the correct fix for this problem. It's Friday and any
help
would
be greatly appreciated.
Dan Shallbetter
States Electric Mfg.
<http://docs.yahoo.com/info/terms/> Terms of Service.
