Custom Code for Job Entry
I would run it after the Initialize Notify is called on the dataview for
job
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Thu, Apr 21, 2011 at 2:35 PM, melanie.kucan <melanie.kucan@...>wrote:
> I would like custom code to be run when a job has been called to be loaded
> in Job Entry. The code works great. This should seem super easy but I am
> overlooking something obvious in the event wizard I hope. I am not looking
> for the On Load event or the List change event. I would like the code to run
> if a New Job is entered and loaded. Can someone please point me in the right
> direction. I am frustrated that I have not figure this out.
> Thank you
I would like custom code to be run when a job has been called to be loaded in Job Entry. The code works great. This should seem super easy but I am overlooking something obvious in the event wizard I hope. I am not looking for the On Load event or the List change event. I would like the code to run if a New Job is entered and loaded. Can someone please point me in the right direction. I am frustrated that I have not figure this out.
Thank you
Set your code on the adapter's 'getByID' and/or 'getnew' method.
> Thank you
